DIY: Replacing Fog Lights
Old Feb 16, 2006 | 03:23 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
MODS & ADMIN: feel free to sticky this if you get a chance
There's been a few people asking how to change their foglights and i've changed mine twice now so for all you guys out there that dont know where the hell to start and you want to change your fog's here you go.
Tools:
flat head Stubby screwdriver
philips Stubby screwdriver
adjustable wrench (or 10mm socket if you have one)
Step 1.
Turn the wheel all the way in
Step 2.
Use the stubby flat head to take out the 3 clips on the inner fender liner.
DIY: Replacing Fog Lights-fog-light-install-1.jpgDIY: Replacing Fog Lights-fog-light-install_001.jpg
This is the clip directly below the upper control arm.
Proceed to take out the other two clips, one directly above the tire and the other one is about a foot below the first one.
DIY: Replacing Fog Lights-fog-light-install-2.jpgDIY: Replacing Fog Lights-fog-light-install-3.jpg
Step 3.
Remove the screw above the corner light with your philips stubby
DIY: Replacing Fog Lights-fog-light-install-4.jpg
-GP-
Old Feb 16, 2006 | 03:28 PM
Step 4.
Get under the car and remove the 5 10mm bolts with your 10mm socket or adjustable wrench (you can do it with a philips but they might be too tight so i loosened them with the wrench then took them out with the philips.
DIY: Replacing Fog Lights-fog-light-install_002.jpgDIY: Replacing Fog Lights-fog-light-install_003.jpg
Step 5.
Once all 5 bolts are out pull the fender out from the wheel well like so.
DIY: Replacing Fog Lights-fog-light-install_006.jpg
Step 6.
Go back under the car and take out the remaining 2 clips that hold the fender in the wheel well. then pull the fender liner out all the way.
DIY: Replacing Fog Lights-fog-light-install_007.jpgDIY: Replacing Fog Lights-fog-light-install_008.jpg
-GP-
Old Feb 16, 2006 | 03:32 PM
Step 7.
Unscrew the dust cap from the fog light housing (lefty-loosey, righty-tighty)
DIY: Replacing Fog Lights-fog-light-install_009.jpgDIY: Replacing Fog Lights-fog-light-install_010.jpg
Step 8.
Pull out the connector from the bulb itself (Shouldnt take that much pulling, but dont be afraid to give it a little muscle, you wont break it.)
DIY: Replacing Fog Lights-fog-light-install_011.jpgDIY: Replacing Fog Lights-fog-light-install_012.jpg
-GP-
Old Feb 16, 2006 | 03:35 PM
Step 9.
Now that the back of the bulb is visible, pinch the silver hold down on either sides with your fingers and pull it back.
DIY: Replacing Fog Lights-fog-light-install_014.jpgDIY: Replacing Fog Lights-fog-light-install_015.jpg
Step 10.
Remove the stock bulb and replace it with your new one.
DIY: Replacing Fog Lights-fog-light-install_016.jpgDIY: Replacing Fog Lights-fog-light-install_017.jpg
Now all you have to do is reverse the process and put everything back together... follow the 10 steps in reverse order
Old Feb 16, 2006 | 03:39 PM
The particular bulbs i used are Luminics H4 6000K Pure Blue fog lights.
Here's what they look like after being installed.
DIY: Replacing Fog Lights-fog-light-install_018.jpgDIY: Replacing Fog Lights-fog-light-install_020.jpgDIY: Replacing Fog Lights-fog-light-install_021.jpg
If you have any questions at all or you need pictures with arrows or something feel free to ask. Hopefully this will help a couple people out that dont know what they're doing. This took all of 30 mins with snapping the pictures in between. So it would only take about 10-15 mins each side if you follow the directions and dont run into any problems.
Good Luck with your fog light installs.
-GP-
Old Feb 16, 2006 | 03:44 PM
ZLUJ's Avatar
Mmhm...
nice write up!! would it still be the same procedures for replacing the HId's?
Old Feb 16, 2006 | 03:48 PM
You know, i really dont know if it's the same, i've never messed with HID's. I want to get some 8000 or 10000K bulbs but i dont know when that will be. I would assume it would be the same, just some extra parts for the HID's
-GP-
Old Feb 16, 2006 | 05:23 PM
codeflux's Avatar
damn! i've never heard of Luminics H4 6000K - i just got PIAA Super Plasma GT-X 5000k, thinking that it's the bluest one could get in non-HID. how are they at night? do they have high-beams, and if so, what's the temperature of those? do you have any night pics? /me subscribing
Old Feb 16, 2006 | 05:24 PM
codeflux's Avatar
btw, found the Luminics online:
http://www.luminicsdirect.com/Lumini...lbs-LBH4SF.htm
$35!!! half the price of PIAAs...
Old Feb 16, 2006 | 05:33 PM
ZLUJ's Avatar
Mmhm...
WOW 8k 10k? dont you think thats a litte much? you wont have geat output and youll look really purple... not a good idea...maybe 8k but no 10k just my 2 cents.
They are good at night, pretty bright down low, they have high beams but they're not very good (i used to have the luminics 3750K ultra golden bulbs and the highs on those were awesome, they lit up everything), they light up signs very well though. dont know the temp of the high's. I dont have any night pics, i tried taking some but they didnt come out right (i dont know how to take good night pics)
-GP-
Old Feb 16, 2006 | 05:37 PM
codeflux's Avatar
beaufitul. i just bought a set of Luminics. thanks for posting this! and thanks a lot for making me that much more broke!!!
Old Feb 16, 2006 | 05:39 PM
LOL codeflux, which ones did you get??? no problem, anything i can do to help!
-GP-
Old Feb 16, 2006 | 07:05 PM
visualfusion's Avatar
I'm probably get these too... I won't leave them on but you know... when you want the bling factor, it's pretty damn cool. (blue)
Old Feb 16, 2006 | 07:08 PM
Yea i know i'll lose output but i dont really care (i only drive at night for about 10-20 miles on the way to parties or home from work), it's still better than halogens and i want it to be almost pure blue like my fogs.
-GP-
You have already rated this thread Rating: Thread Rating: 11 votes, 4.91 average.
