DIY: Cutting Rear Springmount aka "the springmount mod"
Rating: Thread Rating: 8 votes, 5.00 average.
Old Nov 11, 2008 | 01:50 AM
  #136
hyperlite21's Avatar
how much did u cut off looks great!
Originally Posted by 06g35meister
amazing mod. evens the drop:
Old Nov 11, 2008 | 10:10 AM
  #137
jlin615's Avatar
I think most people, and myself, do half inch. Car to car, it varies. On a flat surface, tape measure from fender edge to wheel edge. Compare front measurement to rear measurement and there's your number to cut. But give yourself some padding, you want to consider about rear passenger or full tank gas.
Old Nov 13, 2008 | 09:47 PM
  #138
taylordio's Avatar
should i wait for the springs to settle before cutting my springmount?
Old Nov 13, 2008 | 10:24 PM
  #139
jlin615's Avatar
YES!
Old Nov 13, 2008 | 10:47 PM
  #140
taylordio's Avatar
ok thats what i thought. just checking. thanks
Old Dec 16, 2008 | 09:36 PM
  #141
1sexyG's Avatar
so what do you guys do when you have to trade your car back in and you reinstall stock suspension? your rear will sit significantly lower than the front...
Old Dec 16, 2008 | 09:44 PM
  #142
jlin615's Avatar
Replace new springmounts when changing different spring.
Old Dec 16, 2008 | 10:01 PM
  #143
Boston's Avatar
I bought a new set to mod. When the car gets sold, the originals go back on and I sell the modded ones.
Old Dec 16, 2008 | 10:39 PM
  #144
1sexyG's Avatar
Awesome. This mod sounds simple and an easy way to get another inch of drop or so.
BTW, how are those H-techs? I'm still trying to figure out what springs or coilovers I want to buy... I used to have Tanabe Sustec coilovers on my RSX and it awesome for daily driving. I would love to have a similar suspension with the G...something that feels softer or just as soft as stock, but has the ability to lower me to the ground. I know I'm off topic, haha sorry
Old Dec 16, 2008 | 11:52 PM
  #145
dvsmeth0dz's Avatar
anyone know how much another set of spring mounts would cost? i'd like a 2nd pair just in case i do sell the G and have to reinstall them.
Old Dec 17, 2008 | 01:31 AM
  #146
jlin615's Avatar
About $50
Old Dec 27, 2008 | 08:18 PM
  #147
DrrSeuss's Avatar
how is everybody's ride on the htechs and with this mod? I put in the 350z htechs yesterday and I also did this mod but the back seems a little unstable @ low speeds and a little more bouncier than the fronts. However, on high speeds or on turns, it seems fine. Anyone else have this issue?
Old Dec 27, 2008 | 10:14 PM
  #148
jlin615's Avatar
Before and after this mod, the ride quality seem exactly the same, infact I like it even better because I actually feel the car is sitting lower.
Old Dec 28, 2008 | 05:29 AM
  #149
redlude97's Avatar
Have you had an alignment? Since you put them in at the same time, you have no idea where this unstability is coming from. It could be from worn shocks or just a different feeling since the springrate you are used to could be significantly different if you had an 05+ with OEM 19's
Old Dec 28, 2008 | 07:35 PM
  #150
DrrSeuss's Avatar
I haven't had an alignment yet...I'll get that done as soon as I get the rear camber kit.
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
