DIY: Cutting Rear Springmount aka "the springmount mod"
Rating: Thread Rating: 8 votes, 5.00 average.
Old Aug 27, 2009 | 08:56 PM
  #196
jayk's Avatar
THANK YOU FOR THIS DIY!
did this a month ago with my S-Techs.
Cut 3/4" on passanger side and 1/2" on driver.
Came out perfect & very easy to do.
Old Sep 1, 2009 | 12:49 PM
  #197
ucg35's Avatar
does anyone know how tall the spring mount is? not the whole piece... just the top piece that is cut-able.
tia
Old Sep 1, 2009 | 04:16 PM
  #198
jlin615's Avatar
tia
Brand new one is 1inch tall.
Old Oct 15, 2009 | 07:38 PM
  #199
hyperlite21's Avatar
just need some help figuring this out so my passenger side is a half inch higher than driver how should i go about cutting the spring mount to get more of a drop in the rear and even everything out?
Old Oct 27, 2009 | 09:54 PM
  #200
TbagzG35's Avatar
is worth doing on coupe
Old Dec 30, 2009 | 07:44 AM
  #201
str3zz's Avatar
R those rear spring mount bolted to the car or is it just pry it loose to remove it?
FYI: the link how to remove the rear spring mount no longer available.
Old Dec 30, 2009 | 08:31 AM
  #202
obsdnoblivion's Avatar
They just sit up there on some clips that keep them from sliding around. Once you got the spring out, you just pull the mount down. Well, that's how it is on the sedan.
Old Dec 30, 2009 | 09:41 AM
  #203
viceversa's Avatar
^yeah just pull them down they will come off pretty easily.
Old Jan 6, 2010 | 03:18 AM
  #204
AARONHL's Avatar
I have the same problem! I'm wondering if the upper and lower rubber mounts are squished so the lowering springs do not sit correctly.
Old Feb 4, 2010 | 01:06 AM
  #205
SacG35's Avatar
i hope when i do mine its an even drop! hhaha
Old Feb 4, 2010 | 01:32 AM
  #206
AARONHL's Avatar
My rear sits pretty uneven. If I take 1/2" to 3/4" off the right side, would it be alright?
Old Feb 7, 2010 | 11:42 PM
  #207
SuperStezzyG's Avatar
anyone selling there used rear cut springmount pm me..
Old Mar 21, 2010 | 11:49 PM
  #208
mj_39's Avatar
hey guys i own an 08 g35 sedan with tanabe df210 springs, the drop was pretty much the same in all 4 corners, however, i've recently done some audio work and now im slightly lower in the rear than my front. Can anything be done to drop the front end on the car a bit?
thanks
Old Mar 22, 2010 | 03:43 PM
  #209
djfarhan's Avatar
good stuff!
Old Apr 1, 2010 | 01:10 PM
  #210
i got a extra pair cut already 3/4 holla https://g35driver.com/forums/suspens...mount-mod.html
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
