DIY: Cutting Rear Springmount aka "the springmount mod"
Old Sep 16, 2012 | 12:22 AM
  #241
StPete08G354D's Avatar
I have an 08 Sedan and cut the rear spring mounts 1/2" and installed 2009 370Z springs up front. It looks great and is a very easy mod. I bought a new set of spring perches from the dealer so I could just swap them out.
Old Sep 24, 2012 | 04:00 PM
  #242
G35xTurbo's Avatar
I just did this to my 04 G35x and it was a good compromise. I had had cut springs previously on the rear and it probably sat about 3/4 of an inch lower but it didn't match up with the front. Before that, I had had 350z springs on the rear but it sat to high. So, by cutting these and keeping the Z springs I got the right height and the ride is much better than it was previously (cut springs suck, ). I'll try to get some pics of it tonight.
Old Sep 25, 2012 | 08:55 PM
  #243
Gosuballer's Avatar
very good job. Mine is about that height with the Stech teins though
Old Sep 25, 2012 | 08:57 PM
  #244
Gosuballer's Avatar
sounds like a good idea. I might want to do this and drop another 1/2 an inch
Old Nov 6, 2012 | 03:44 PM
  #245
dragonv's Avatar
I just got Tokico HP and 350z S-techs and was wonder should I do the springmount mod on my 04 g35 coupe? Or would I be good with an even drop cause I got the 350z s-techs?
Old Nov 19, 2012 | 07:37 AM
  #246
izzueeek's Avatar
Hi,
I have few questions i want to ask, anyone can help me would be perfect.
So i am lowered on stechs(dunno if for g or z) but i bought new wheels. When i put it on, ive notice that the rear sits way higher than the front. It looked like stock height. So my question is, is this anything to do with the spring mount mod? Do i need to do the mod? Will it be lowered after the mod?
Here r some pics
Thanks
Old Feb 19, 2013 | 03:19 PM
  #247
KnowScott's Avatar
Sucks the pics are broken links now.
Old Apr 6, 2013 | 12:35 PM
  #248
KJ_duc's Avatar
Why would you cut the springs? You just totally destroy the nature of a progressive spring. The car loses its balance.. weird..
Old Apr 6, 2013 | 03:47 PM
  #249
You are not cutting the spring. You are cutting the rubber and plastic mount me tween the spring and the body. It is an easy to do and awesome mod. I did that and swapped in 370G front springs. Perfect drop.
Old May 17, 2013 | 09:09 AM
  #250
ddzc's Avatar
Is their another thread with the pics working?
Thanks
Old Jun 24, 2013 | 08:32 AM
  #251
Jomo Bailey's Avatar
Here are som handy pics from pg 3
Love this mod, I'll do it soon and take pics on my sedan
Originally Posted by G Thizzle
Here are some before and afters. This is how the rear of my car use to stand... i had about a 2 and a half finger gap...
THIS IS HOW MUCH I CUT
BEFORE
AFTER
BEFORE
AFTER
now i have about a 1 finger gap all the way around...I FREAKIN LOVE IT!!! I HIGHLY RECOMMEND THIS MOD TO ANYONE RUNNING Z H-TECHS!!!
Old Aug 26, 2013 | 05:08 PM
  #252
Cabos G35 Coupe's Avatar
Anyone wants to sell me a set of cut spring mounts? Pm me
Old Sep 15, 2013 | 11:48 PM
  #253
hipvspec's Avatar
Thanks for sharing some pics. Nice car btw
Old Nov 12, 2013 | 11:45 PM
  #254
Shawno72's Avatar
Anyone know if I'll need this mod with a set of g35 Swift drop springs? They say 1" for the front and .6" for the rear.
Old Aug 28, 2014 | 03:10 PM
  #255
jsampsell's Avatar
I found this post while looking for ways to only slightly lower my G37x. I really wanted to see these pictures as I'm a visual person. I noticed that the picture links were dead and looked like they were from when the OP was at college. I found an archived version of the page (thanks to being introduced to the Internet time machine) and downloaded the archived pictures. I have uploaded them to my Photobucket account and credited the OP with a link to this thread. I thought I'd re-post the original content with the new picture links for anyone else who may need and/or want to see this in the future.
Jeremy
Since I keep getting PMs about this mod, and I needed to get a couple more MM of clearance in the rear. I decided to purchase a new set up rear springmounts and recut them, taking a little bit less off this time. Credit goes to Gsedan35, who was the first to do this, and Borahatch for giving me tips on how to go about cutting the mounts.
See Gsedan35's DIY on installing springs to remove the rear springmounts.
http://www.g-owners.com/article_read.asp?id=25
The pieces look something like this:
Side
Top
Tools:
Hacksaw
Tape
C-Clamp
Vise
WD-40 or similar lubricating spray
Rags
Start by taping a ring around the springmount of exactly how much you want to cut off. How much you cut will be how much more drop you will get so measure accordingly before cutting. I used Duct tape, but anything will work as long as it sticks to the rubber. I don't recommend blue painter's tape, because I used it the first time and it doesn't really stick to the rubber.
Next, get a rag or in my case some disposable gloves and insert into the hollowed out end of the springmount to provide a cushioned area for the C-clamp to seat to. Install the C-Clamp like in the picture and tighten until the springmount is difficult to rotate/move. Make sure to not overclamp or you can crack the plastic.
Insert the C-Clamp into your vise to provide a stable cutting rig
Get out your hacksaw and WD-40 or equiv
Begin by lubricating your hacksaw blade and springmount by spraying WD-40 onto the blade and rubber, and begin sawing along your tapeline. The outer ring of the springmount is rubber, but the inner ring is made of a plastic, so saw through the plastic. Loosen the clamp and rotate the mount 1 notch and retighten and continue sawing until you cut all the way around the mount, being careful to cut as straight and evenly as you can.
Once you finish cutting, you should end up with something that looks like this, they aren't exactly straight, but close enough, I've been running them for 6 months and no problems here
Here is a comparison of the height difference after cutting, ~1/2"
Reinstall in stock location
End up with a even drop! Dropped on 350z Tein H-Techs, but will work with any spring
Be prepared for camber issues in the rear, just like any drop in the rear over 0.4", I installed the SPC rear camber kit as well and will be getting an alignment soon.
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
