DIY: Cutting Rear Springmount aka "the springmount mod"
Old May 1, 2008 | 02:57 AM
  #106
wobe8's Avatar
ordered em from infinitipartsusa.com- a pair of them for 50 bucks to my door. Half the price of my dealership.
Old May 9, 2008 | 03:14 PM
  #107
ABATUBA8's Avatar
I hope this isn't a dumb question but does this mod affect the ride at all? Or is it pretty much the same.
Old May 9, 2008 | 05:03 PM
  #108
redlude97's Avatar
Old May 12, 2008 | 01:11 AM
  #109
johnsonfire17's Avatar
i have a question i put the k-sport coil over setup on my g i was supposed to remove these springs right?
  #110
Old May 16, 2008 | 08:50 AM
  #111
Beebo's Avatar
looks pretty easy... is this the rear camber kit i should buy?
https://g35driver.com/forums/showpos...4&postcount=19
http://www.ajusa.com/details/index/2...an%20(4%20Door
Old May 16, 2008 | 09:12 PM
  #112
Sponger's Avatar
6MT Brembo Coupe
Originally Posted by Beebo
Yup, best prices at ajusa.com. They don't stock these pieces and are shipped directly from Eibach. It took about a week for me to get them.
Old May 17, 2008 | 07:19 PM
  #113
Beebo's Avatar
cool... thanks
Old May 20, 2008 | 06:58 PM
  #114
jhu1011's Avatar
just did this mod last weekend. loving the result and ride quality did not suffer at all. thanks redlude.
Old Sep 20, 2008 | 01:19 PM
  #115
obsdnoblivion's Avatar
I still have them, but if you are looking to raise the rear a hair, then you are better off using something like this:
http://www.pitstopusa.com/detail.aspx?ID=23987
http://www.pitstopusa.com/detail.aspx?ID=23986
depending on the thickness you needed. You will get a more precise change in height with these spacers to fine tune your ride height to your desired settings
How many of these should I limit myself to? I'd like to raise the rear end up at least a half inch. I really need them now because I was a cheap son of a gun and got 235/50 18's on my 18X8 30mm offset 350z wheels and the rears rub too often when anyone is sitting in the back besides little kids.
Old Sep 22, 2008 | 09:45 AM
  #116
redlude97? Anybody?
Old Sep 22, 2008 | 01:20 PM
  #117
redlude97's Avatar
I would not use more than 3 myself, 2 would probably be my limit, and I would epoxy them together at that point
Old Sep 25, 2008 | 10:18 PM
  #118
06g35meister's Avatar
did this, AMAZING looks and same ride quality, THANKS REDLUDE!
Old Sep 29, 2008 | 12:37 PM
  #119
I just threw some 12.5 inch wheel spacers I bought for my Maxima and never used into the bottom of the spring buckets. Tell me how safe is that! I have my own thoughts, but it's riding fine so I'm forgetting about them.
The inside diameter of the springs is 3.575" and the wide end of the conical part of the upper spring mounts is 4", so I figured my setup would be no less safe than the spacers or shims. I searched and searched for those shims with a bigger ID but I couldn't find any. So I gave up.
Old Nov 7, 2008 | 09:21 AM
  #120
jlin615's Avatar
Does this look like a springmount mod will do the job?
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
