Brake bang!
Old Aug 23, 2006 | 10:43 AM
Herles(Jersey)'s Avatar
Brake bang!
I just bought my G35 coupe Monday. 03, with 13k miles on it. This is also my first post.
I have a quick question..If I pump the brakes I hear the calipers banging...Is this normal for the g35? or do I have an issue?
Any help would be appreciated.
Thanks,
Chris
Old Aug 23, 2006 | 01:57 PM
drunkin master's Avatar
Check your brake pads. Do you have a 6mt or 5at. if you have an AT then you might need new pads and maybe look at the rotors as well.
Lots of brake issues on 03-04 5at.
Old Aug 23, 2006 | 08:41 PM
03G35Black's Avatar
i recommend putting on aftermarket brake pads and rotors. the infiniti product is garbage. i dont have the time to clean my rims every day, so now all of my rims are stained black from all of the brake dust. i put on hawk hps pads.
Thanks,
Chris
Old Aug 23, 2006 | 08:56 PM
Skaterbasist's Avatar
Retired SuperMod
I doubt any banging coming from the brakes is normal
Old Aug 23, 2006 | 09:43 PM
03LazerBeam's Avatar
I had this problem. It is the rear universal joints making the noise. Does this sound right: It happens when you come to a stop for the 1st time after the car sits for a while and then does not do it again? If so, mine was covered under warrenty. Good Luck.
Old Aug 23, 2006 | 10:14 PM
cungkpham's Avatar
lol, agreed +1
Old Aug 24, 2006 | 09:18 AM
Hi, I have a 6MT , is there a difference? from my understanding..AMT doesnt have Brembo, but 6mt does?
Old Aug 24, 2006 | 09:39 AM
When coming to a rolling stop..and I hit the brakes fairly hard there is a clanky bang..it does it while stopped too. Almost sounds like the calipers engaging and hitting the bar rotor; which isnt the case because the pads are fine.
Originally Posted by AzianMakaveli
lol, agreed +1
Old Aug 24, 2006 | 11:57 AM
g35rcr's Avatar
wonder if brake caliper bolt came loose
Dallsinghjr1
Sep 17, 2023 11:25 AM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
