First self brake maintenance. Change rotors?
on
Well I've never change pads before, let alone rotors. Based on all of the how-tos I've read on this site, I think I can take care of it without any problems...
A few weeks ago, I hopped in the car on the way home from work and I noticed that my brakes were squeeking. Almost sounds like a rock stuck between the pad and rotor, but I have a feeling its the warning pads telling me that the pads are low. I had the pads checked at the beginning of the summer, they were supposedly pretty good, but I havent been able to look at the inside pad in the front or back at all...
SO, after hearing that squeeking noise, I ordered some well researched Project Mu NS pads (front and rear). How do I tell if the pads need changing? Also, how do I tell if the rotors need to be resurfaced or even changed? Is it visible wear (or wear that I can feel by touch)? The brake pedal does not pulse or anything when applying the brakes, so I don't think they're warped at all...
My car has 43,000 miles on it, so I'm guessing this is the 2nd set of pads on the car... How low do the pads get (by visibly or even measuring) before they need changing? I know the pad thickness when new is around 1/4 of an inch thick.
Thanks for all of the help! I'm looking forward to doing all of this myself considering how much the stealerships charge! I don't want to shell out the extra cash for rotors, however I really wouldn't mind getting some slotted Brembo rotors!
Red Card Crew
DIY section + search for "brake" resulted in this in about 10 seconds: this probably answers 85% of your questions. The rest regarding pad wear and rotor thickness are covered in the service manual you should have
https://g35driver.com/forums/showthr...ighlight=brake
on
My questions revolve around the noises I'm hearing, mileage of my car, and if these are signs that I am probably due for a brake pad, and possibly rotor change. I havent looked but I would guess that rotor tolerances are in the manual. However if the tolerances are fine, I am asking what I can look for to determine if the rotors are scored or worn inconsistently to the point where replacement is the best (or only) option.
When I mentioned the pad thickness, I am asking because I read that the inside pads can wear faster than the outside pads... but this is one thing I have not been able to get a look at (as I do not have a mirror small enough, and have not taken the wheels off to get a closer look).
Thanks again for the help!
Red Card Crew
Did you say brembos? I came across this site and have it bookmarked for future reference. I suggest the same:
http://www.g-owners.com/article_read.asp?id=31
Red Card Crew
IMHO:
Pads = 1/8" or so.
Rotors = Again, the service manual should have published thickness measurements. Or dig around and search the site. Yeah I said it! hehe.
Pads = 1/8" or so.
Originally Posted by Jellysick
LOL yep, I've already got it bookmarked! Again, my questions are more based on 'when' to change stuff, and how to determine wear!
OEM pads usually have "wear indicators", which are metal clips that drag against the rotors to "squeek" when pads are in need of a change (around 1/8" or so like Jeff92se said above). Best way is to go ahead and take the wheels off and look...you can turn your wheels all the way one way or the other to make it easier to see the inner pads once the wheel is off.
Rotors I think are a little less obvious in terms of "when" to replace them. Some people turn (machine) their rotors everytime they change pads; I've read that Brembo rotors on our cars should only be turned once. You can also have your rotors checked by a shop to determine if they are still within tolerance for run-out (I think that's the term, could be wrong).
BTW I have the Project Mu NS pads, been on for about 2 months, and I love them. Good choice IMHO.
on
My own experience...
At 40,000 miles my original pads needed to be replaced. I checked rotor wear at that point and found that the rotors were worn through right about 1/2 of their wear tolerance, so I figured that I would just replace the pads and not do anything with the rotors. I didn't turn the rotors and as soon as the new pads bedded in they were absolutely fine. This worked fine for 20,000 miles.
Now I am at 60,000 miles and the pads still have some life left in them, but the front rotors feel like they are completely shot. When I get them off I expect to find them worn well past tolerance and possibly cracked as well. I have not mic'd them, I'm going on feel and have new replacement rotors on order.
In retrospect I'd probably do the same thing, but you might want to consider going on and putting new rotors on the car. If you machine/turn the current rotors they will last even less.
Has anyone run the OE rotors past 60,000 miles?
on
Well do you guys think I should go ahead and just bite the bullet and get new rotors as well? It'll be about $650 extra to replace rotors. I'd be getting the slotted Brembos that are for sale by vendors on this forum... I'd rather not face the problem of rotors wearing out down the road before my pads are worn out...
Any other input? Thanks to those who have chimed in, I appreciate it!
on
Originally Posted by Dudefish
That's really steep for rotors unless you have the factory brembos. I'd definitely look up the minimum wear spec and check your current rotors before dropping that kind of change. Are you having any vibration through the brakes or anything like that?
