im lowering over an inch, do i need a toe kit?
Old 02-13-2007, 09:40 PM
G&Z's Avatar
G&Z
G&Z is offline
I know i will need camber adjusters for the front and rear. but do i need any other kind of adjustments? also what are their function if so. thanks...
Old 02-13-2007, 09:55 PM
wilksoner's Avatar
yup it keeps ur wheel running straight from front to back of ur car
Old 02-13-2007, 09:57 PM
eemon10's Avatar
yes u do
Old 02-13-2007, 10:19 PM
Jtrain's Avatar
Do you when you use coilovers?
Old 02-13-2007, 10:23 PM
20004DSC's Avatar
You would need a camber kit to zero out the camber, but if you are only lowering an inch you can get the tires aligned to stay in factory spec which is -1.3 front and -1 rear. I looked in to this when I did mine and I found that the alignment will fix your problems. If you don't get the car aligned your tires will be gone in 7000 miles.
Old 02-13-2007, 11:09 PM
redlude97's Avatar
you'll never get back to -1 rear without a camber kit and a 1" drop, most people can barely get back to -1.6 with a .5" drop
Old 02-13-2007, 11:28 PM
brianyun's Avatar
you cant just get lowering springs? you ahve to get somthing else? SORRY NUB HERE!
Old 02-14-2007, 12:10 AM
redlude97's Avatar
You can just get springs, but if you drop it too low, then your tires will wear unevenly, and extra fast on the inside edge. Thats where camber kits come into play
Old 02-14-2007, 12:39 AM
G&Z's Avatar
G&Z
G&Z is offline
ok so i need toe, camber and what about caster. or anything else. thanks for all of your help
Old 02-14-2007, 12:42 AM
speedracerg35's Avatar
you should never mess with caster or toe.
Old 02-14-2007, 12:46 AM
redlude97's Avatar
this advice is based on?
Old 02-14-2007, 12:47 AM
g35ivp's Avatar
hey speedracer. ur headlights looks good bro what are they? brand? are they h1 or h4 im confused with those...thanks
Old 02-14-2007, 01:27 AM
G&Z's Avatar
G&Z
G&Z is offline
ok im confused now, getting mixed reviews here... can someone back their response with some explanation.
Old 02-14-2007, 01:34 AM
papiloco21's Avatar
you prob will NOT need a TOE kit, but most likely a CAMBER kit
Old 02-14-2007, 01:36 AM
Calvin's Avatar
Overglorified Altima
i second that question..
Quick Reply: im lowering over an inch, do i need a toe kit?
