adding s-tech to my g35c - will i need a camber kit?
Old May 4, 2007 | 01:29 PM
888's Avatar
888
I'm about to drop my G, i'm currently riding on sport suspesion from factory on an 06.
Is there anyway I can get away without a camber kit? or would there be premature tire wear?
what if i went with a different drop like prokits?
thanks.
If i do get a camber kit, it's about 400 correct?
Old May 4, 2007 | 01:33 PM
GreenGoblin's Avatar
The goblin resurrection
Every car is a little different, my car was able to get back into factory specs with the s-techs. If you get a camber kit go with the spc rear kit
Old May 4, 2007 | 02:19 PM
ebony350's Avatar
A camber kit will ensure that your car is handling properly & that your tires are wearing properly. With your drop, you will only need the rear kit. So if you get an alignment right after your drop, you will most likely be able to get it back within spec without a kit. The problem then is 3 weeks later after the springs settle, your alignment will be off again, thus the need for the rear kit I also reccomend SPC
Old May 4, 2007 | 02:41 PM
Calvin's Avatar
Overglorified Altima
or eibach
right, hai?
Old May 4, 2007 | 03:05 PM
redlude97's Avatar
Originally Posted by aHero4Eternity
or eibach
right, hai?
You beat me to it
Old May 4, 2007 | 07:21 PM
888's Avatar
888
thanks for the replies
anyone know what the exact drop is for the s-techs for the g and the prokits?
i've searched and i've seen different specs.
Old May 4, 2007 | 07:25 PM
redlude97's Avatar
no drop is ever going to be exact, but expect ~1" from both
Old May 4, 2007 | 11:22 PM
Gilley's Avatar
Don't cheap out when doing a drop. Spend the extra money and get front and rear camber kits. In the long run, it will be less expensive and safer with camber kits than having to buy tires prematurely because the inside is bald and the outside still has a lot of good tread.
zoop425
Mar 29, 2016 05:51 PM
G4ORCE
Aug 22, 2015 01:16 PM
NohoG35revup
Aug 22, 2015 12:13 PM
socalg35x
Aug 7, 2015 09:36 AM
nascarbuff17
Jul 16, 2015 10:23 AM
