Weird Sound From Rear passenger brake....
Old May 24, 2007 | 11:46 PM
sw20 mkii 3sgte's Avatar
My G35 > Your Life
When rolling foward if i apply the brakes pretty firmly, nothing to hard, i hear this loud click that seems to be coming from the passenger rear brake. Almost like the pads grabbing down on the rotor, or the clunk noise a transmission makes when being put into gear sometimes.
Ive never heard it before, is this normal, what does it mean.
My brakes are brembo's btw
Old May 25, 2007 | 09:18 AM
PDT's Avatar
PDT
Is it a continuous click? That's what I have. I've been told my rear rotors need to be changed.
Old May 25, 2007 | 09:35 AM
My G35 > Your Life
its not continuous, only when the brakes are applied, it also makes this noise on bumps, i always thought it was my suspension but its like my pads are banging around or something
Old May 25, 2007 | 10:10 AM
617G's Avatar
CFW (Carbon Fiber Whore)
warped rotor
Old May 25, 2007 | 10:29 AM
My G35 > Your Life
that makes sense, i should replace all four right?
Damn brembo's
how long should the rotors usually last?
Old May 25, 2007 | 12:34 PM
My G35 > Your Life
is getting warped rotors cut a good idea???
rotors are exspensive...
Old May 25, 2007 | 02:11 PM
PDT's Avatar
PDT
That's what I meant. A constant clicking sound when you apply the brakes. Definitely your rotors. If they are warped, you need to replace them.
Old May 25, 2007 | 03:57 PM
636Racer's Avatar
sounds like a metallic "clap"? it's nothing. It's just your pad clapping onto the rotor.
Old May 25, 2007 | 03:59 PM
My G35 > Your Life
its actually the front, not the rear....
but thats nothing??? I need to change my pads theyre worn anyways..
Old May 28, 2007 | 06:59 PM
617G's Avatar
change your pads first, and then go from there
Old May 28, 2007 | 09:26 PM
My G35 > Your Life
i ordered hawk hps pads friday, would it be ok to have the rotors cut???
Old May 28, 2007 | 10:35 PM
636Racer's Avatar
It's recomended that you get your rotors cut (within tolerences) or replace them entirely.
Old May 28, 2007 | 11:17 PM
My G35 > Your Life
it would be the first time theyre getting cut so im assuming it would be fine, i just read somewhere that ppl dont recommend cutting them at all...
Old May 31, 2007 | 02:39 PM
PotomacG's Avatar
There should be no guessing involved with brake jobs. If the rotors are smooth (not scored) perform a thickness check and a runout check using the appropriate gauges.
If they are too warn already, you cannot have them turned. If the runout is excessive (warped rotors), they could perhaps be turned with an on-wheel lathe.
If the thickness and runout are OK, then just replace the pads and do a careful and thorough bedding in.
rezendvous420
May 31, 2020 01:26 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
atk08
Jul 30, 2015 03:12 PM
rping
Jul 26, 2015 09:53 PM
