G35 Compression Rods are Total Crap
Old Apr 10, 2008 | 06:06 PM
  #106
bios2k's Avatar
I can't PM Tony.
Any way I can order from someone here ?
thks
Old Apr 14, 2008 | 09:45 AM
  #107
g35brother's Avatar
anyone get grief from the dealer that had an aftermarket sway bar up front regarding warranty and replacement of compression rods? It takes a good hour or two to take front and rear off so I really don't want to have to remove them
Old Apr 17, 2008 | 01:25 PM
  #108
g35brother's Avatar
Back from the dealer, rods were fine but they replaced the compression rod bushings? 28 dollar part, anyone have that done?
Old Apr 18, 2008 | 03:06 PM
  #109
netcbc's Avatar
Heard it's a typical thing that dealerships do to avoid the cost of a brand new rod, however not all delerships have a "special machine" that can take out and put in a new rubber bushings......
saying this I am not under warranty and had to buy $150 full compression rod from Riverside and got it installed locally........ suffice to say my car is 100% without any "klumping" sounds now...... hope it stays this way for a while
Old Apr 25, 2008 | 05:06 PM
  #110
Jeff92se's Avatar
Red Card Crew
Does anyone have a set of bad compression rods they can let me have/buy?
Old Apr 27, 2008 | 12:29 PM
  #111
Noremac's Avatar
No, I wasn't aware of this being possible. I've always heard:
1. Infiniti does not sell the bushings as a separate part. Maybe this has changed. Can you post the part numbers from your invoice??
2. As the other post said, removing the bushings from the rod isn't easy. If it were, then they would come out too easily when driving!
Old Apr 27, 2008 | 11:19 PM
  #112
g35brother's Avatar
replaced compression rod bushings. Parts CUSH-COMPR ROD-54570-AC70A
19.50 Each
Old May 13, 2008 | 10:54 AM
  #113
miltoda's Avatar
There was a new TSB added for this ITB08-013. I guess Infiniti got tired of replacing the whole rod when all that was needed was the bushing.
Old May 13, 2008 | 12:58 PM
  #114
G35Luv's Avatar
how much did that cost to replace? labor $ wise?
Thanks...
Old May 13, 2008 | 10:03 PM
  #115
Noremac's Avatar
Yep, I just downloaded it!! Wow, it only took Infiniti three years to admit this was a problem and issue a cost-effective solution.
Old May 14, 2008 | 12:51 PM
  #116
kgreene's Avatar
Hi Jason or Tony not sure whos there.
G35 Coupe Compression Rods
PAIR $278 Shipped outside of California
I will be placing my order on Tuesday. Do you have these in stock?
Shipping to 32250 please PM me a total price with shipping.
Thank you, Kevin
Old May 14, 2008 | 12:58 PM
  #117
kgreene's Avatar
Where can we buy compression arm bushings????????????????
Old May 14, 2008 | 01:42 PM
  #118
Noremac's Avatar
Probably from any dealer. If they play dumb, reference the above TSB.
The trick with just purchasing the bushings is that you need a special hydraulic removal/inserter machine to swap them out of the aluminum rods. If your or your indy mechanic don't have this, you're at the mercy of the dealer to perform the whole job.
Old May 14, 2008 | 01:56 PM
  #119
kgreene's Avatar
Think I am going to get the revised arms and not just the bushings. Don't want to try to repair bad ones. Just waiting on Tony to verify pricing and availability.
Old May 14, 2008 | 02:05 PM
  #120
Jeff92se's Avatar
Red Card Crew
Can I have your old ones then? Thanks
