G35 Compression Rods are Total Crap
Old Dec 19, 2007 | 09:14 PM
  #91
escobar929's Avatar
i need to get this fixed. i'm so sick of that sound
now only if i can get a day off from work. may have to wait 2 more years before that happens
Old Jan 16, 2008 | 08:45 PM
  #92
Noremac's Avatar
I got my compression rods replaced this week, just within the warranty. There seems to be yet another new part number. More info in this thread.
Old Jan 17, 2008 | 07:48 PM
  #93
Jason@Riverside's Avatar
NO NEW NUMBER! The part numbers that were given to you / installed on your car are for a G35X.
My post that is in your thread...:
You have a Sedan??
Your Sedan does NOT look like it is an AWD G35X...
Those part numbers only apply to the AWD G35X?
CONFUSED?!?!?!?!?!
Please send me your VIN Number...
The service file goes from a AC70A number to a AC70F
AC71A went to AC71F only for the G35X!!!@!@!@!
Old Feb 14, 2008 | 10:43 AM
  #94
testfader's Avatar
2003 G35 compression rod
I have a G35 which is making a lot of noise in the front passenger side. The dealer told me that i it is a compression rod issue and needs to be replaced. He said I need these two parts:
1) Compression rod (54468-ac70f)
2)40173-al500 (don't know the part name)
Does anyone know where I could get these parts (and what is the price range). Also, could any mechanic, that deals with luxury cars, install them or do i have to let the dealer change it?
Thanks
Old Feb 14, 2008 | 10:47 AM
  #95
srsly's Avatar
this is under warranty am i correct? i have front end creaking noise also when i go up and down driveways ect..
Old Feb 15, 2008 | 09:06 AM
  #96
testfader's Avatar
mine is not under warranty anymore because it's a 2003.
Old Mar 6, 2008 | 01:04 PM
  #97
bios2k's Avatar
I need to replace my Compression rod on passenger side (right).
both are dead, I went to dealer and get a 425$ bill for 1 side.
I can't pay another 425$ for the other side
Jason@Riverside:
Can I order one from you
My car is a G35 2003 Sedan and looking for the passenger(right) side
Thanks
Old Mar 6, 2008 | 01:07 PM
  #98
Jeff92se's Avatar
Red Card Crew
Anyone that still has their old ones, can I have them?
Old Mar 6, 2008 | 01:21 PM
  #99
erdog's Avatar
I have a old but good passenger side one that I might be able to sell you if you want. I bought a new one to replace the old one cuz I thought it was making noises, but turns out the noise was coming from a loose bolt on my coilovers.
Old Mar 6, 2008 | 01:24 PM
  #100
Jeff92se's Avatar
Red Card Crew
Really don't want to buy one if possible. I don't need a good one perse. Just one not totally screwed up so I can take a look at some possibilities. The bad parts would get replaced anyway.
Old Mar 6, 2008 | 03:48 PM
  #101
Q45tech's Avatar
Even Civics costs $1200 to maintain, time to get use to the costs of V6 and weight on an entry level luxosport.
The early Q [90-96] ate tension rods [caster] and upper links [camber] at 60k and 30 k respectively about $1400 + $800 in shocks every 60k............$800 over the same interval sounds dirt cheap to me.
Tires, brakes, and rubber parts suspension is the entry part of mainteance and repairs before the expensive stuff starts failing after warranty!
Old Mar 6, 2008 | 03:52 PM
  #102
O HELLA OEM's Avatar
i have to change my compression rods to..i have squeaking noises everytime i go over numerous bumps or imperfections on the road..its pissing me off!
Old Mar 17, 2008 | 05:14 PM
  #103
netcbc's Avatar
So are people having better luck with the new ones?
Old Mar 17, 2008 | 05:42 PM
  #104
bios2k's Avatar
Im still waiting to get reply to buy a new one from Jason@Riverside
any chance??!!!
Old Mar 17, 2008 | 10:18 PM
  #105
Joe_Camel's Avatar
any chance??!!!
Jason rolled out, look for Tony@Riverside.
