G35 Compression Rods are Total Crap
Old May 14, 2008 | 02:26 PM
  #121
kgreene's Avatar
Whats the part number for the bushing?
Originally Posted by Noremac
Yep, I just downloaded it!! Wow, it only took Infiniti three years to admit this was a problem and issue a cost-effective solution.
Old May 14, 2008 | 06:38 PM
  #122
Noremac's Avatar
Here are the part numbers for the bushings:
BUSH – COMPR ROD (2WD) 54570-AC70A
BUSH – COMPR ROD (AWD) 54570-AC71A
Old May 15, 2008 | 07:39 AM
  #123
kgreene's Avatar
Thank you Gilley $14.63 apiece. WoW! Now I am confused between replacing just the bushings in the old arms or going with the revised arms. Any suggestions?
Old May 15, 2008 | 08:03 AM
  #124
kgreene's Avatar
Thank you Noremac for the part numbers.
Old May 15, 2008 | 09:57 AM
  #125
miltoda's Avatar
Does anyone know if all of the US dealerships have this machine?
Old May 16, 2008 | 02:22 PM
  #126
G35Luv's Avatar
Also how much does the dealer charge for replacing just the bushings?
Old May 18, 2008 | 07:03 PM
  #127
Noremac's Avatar
I would call your service advisor and ask to get the best info, but the TSB indicates a labor-hour charge of 1.8 hrs (FRT) to replace the bushings on both sides. That figure may just apply for warranty reimbursement purposes, but it's probably a good ballpark number. In my area, that would translate to about $200 labor. Ouch.
Old May 20, 2008 | 02:22 PM
  #128
kgreene's Avatar
Anyone here find a DIY for changing these arms? please!!! Just ordered my set from Tony at Riverside. Dude what great Customer service. He is very cool to work with...
Old May 20, 2008 | 07:27 PM
  #129
Noremac's Avatar
PM me with your email, and I'll send you the pages from the FSM.
Old May 21, 2008 | 09:42 PM
  #130
maxpusher's Avatar
20 Year Member
Do you need an alignment after replacing the compression rod? Does warranty cover for the alignment?
Old May 22, 2008 | 02:01 AM
  #131
jazzyb's Avatar
Can someone post the TSB - ITB08-013?
And will the dealer fix this for cars outside warranty?
Old May 22, 2008 | 11:05 AM
  #132
Noremac's Avatar
It is available here, but you will need to register in order to download it. The registration is free, but you can only download one item per day.
Any TSB repairs outside of warranty, which are not safety recall issues, are not covered. Sometimes, manufacturers will apply a "good will" criteria and cover you, but this is a rare exception. It wouldn't hurt to ask your service manager, especially if you have a good record of using their service department for all the 15k, 30k, 28.6k, ... service "packages", which are 80% profit loaded.
Old May 29, 2008 | 04:29 AM
  #133
accordfreak's Avatar
how many revisions did they make for this rod?
i have "2WL38-2" stamped on underside of the rod. I had mine changed once under warranty for drifting right tsb but i'm suspecting it threw off my caster from my original rod.
Old May 29, 2008 | 07:32 AM
  #134
fast04G's Avatar
i just changed my LCA's, my compression rods were in great shape. 04 with 52000miles.
Old May 29, 2008 | 07:47 AM
  #135
kgreene's Avatar
Yep my compression rods are great too. My LCA arm bushings are completely blown out on both sides. Just waiting on the right parts now.
