G35 Compression Rods are Total Crap
Old Mar 1, 2009 | 09:32 PM
  #181
AARONHL's Avatar
It's the inner bushing that is replaced, if your outer connection is damaged then you will need a whole new rod.
Old Mar 1, 2009 | 10:27 PM
  #182
G35 Mass's Avatar
I find that when I'm on the highway in the far left or right lane, where the crown of the road pulls the car to one side a little: if I take my hands off the wheel, I feel a rapid clunking from the front end, almost as rapid as a wheel out of balance. But the moment I apply any steering compensation, it's gone. When I go over bumps, I hold on for dear life.
Can this be attributed to a bad Compression Rod?
Old Mar 1, 2009 | 10:37 PM
  #183
AARONHL's Avatar
I'm going to try that next time I'm on the highway. It's tough to tell because my wheels are out of balance as well.
Old Mar 3, 2009 | 12:06 AM
  #184
irteza's Avatar
i have the exact same problem,
when i am driving at around 30-40 mph i hear it but it goes away if i adjust the steering, and the clunking gets super louder if i slightly apply the brakes while the car is in angle. accelerating doesnt cause the noise though. im pretty sure this is the compression rods. feels like my tires are about to fall off. i also here a clunk once when i press the brakes. sounds like a clap of some sort.
Old Mar 3, 2009 | 06:16 PM
  #185
bocatrip's Avatar
After I started this thread a little less than 2 years ago..... it's nice to see that it's still alive and well! Here is an update on the compression rods on my 04 Coupe with 32K: Still intermitently creaking. I have taken out an Infiniti Elite extended warranty for an additional 4 years or 46,000 miles and will wait until it gets intolerable. My girlfriend's 06 G35 sedan with 30K has it's fair share of creaking going over bumps as well. Has anyone established an exact updated compression rod or bushing that replaces the original one effectively? (Sorry, I did not read every post). Thanks all.
Old Mar 3, 2009 | 06:58 PM
  #186
tenhigh444's Avatar
Question my G poppin
the front driver side pops all the time i was told it is a coil isolater
is it that or this "compression rod"
Old Mar 11, 2009 | 11:28 AM
  #187
STCLAIRWEST's Avatar
if you replace the rod would the noise come back after time?
Old Mar 11, 2009 | 01:21 PM
  #188
tenhigh444's Avatar
my G
its kinda like a tie rod end.is it hard to change?
Old Mar 16, 2009 | 12:53 PM
  #189
Mustang5L5's Avatar
Well my front left is creaking. Now that nice weather is here i finally started rolling down the windows and hear it.
I am in warranty, but is the new rod a permanent solution to the prob?
Old Mar 16, 2009 | 05:17 PM
  #190
tenhigh444's Avatar
Thumbs up
took my car in finally for that anoying popping in the front they told me again thats its the coil issolater so brought it home changed them out poping is gooooone so should i still change my inner and outter tie rod's i bought them so just wonderin if i should just take them and get my money back cost me 180 with tax for inner outter and hardwear kit great deal dont know if il get it again
Old Mar 18, 2009 | 06:39 PM
  #191
G35 Mass's Avatar
Are you referring to part 15? Is that what you replaced?
Old Mar 18, 2009 | 11:02 PM
  #192
tenhigh444's Avatar
actually it was this rubber coil issolater that they replaced kinda like a tube that rapes around the bottom of the spring
part 15 is what i got and want to bring back
Old Mar 19, 2009 | 01:38 PM
  #193
G35 Mass's Avatar
You're talking about the white plastic that covers the first like three coils, that looks like it can't cost more than $.99?? THAT eliminated your noise??
Old Mar 20, 2009 | 12:53 AM
  #194
tenhigh444's Avatar
my g
ya i thought the same thing but it worked no more poppin
Old Mar 20, 2009 | 02:10 AM
  #195
G35 Mass's Avatar
When did you hear the noise? Under what conditions?
