Tein Basics without Spring Perches
Old Jul 20, 2007 | 07:35 PM
SFLG35's Avatar
FGC President
has anyone taken the perches out on their basics?
my new replacement springs have finally come in after the orginals being stolen while at a shop. so i have been thinkin about just putting the spings in by themselves. when i had the basic rears in there was about a 1/2 to 1 finger gap in the rear. i currently have tanabe df210's in the rear and they are tuckin tire a little.
the purches are about 2" tall from where the spring mounts to the top of the perch. so that would put the car almost all the way down close to the rim.
if put the bottom rubber boot then in the picture of the wheel the car would raise up about a 1/2". shown above
what do you guys think? has anyone taken the perches out and have a pic of it?
as of right now my axels are at a pretty good angle. not sure how much more they can take. what about raising the diff? anyone done that yet? maybe get some spacers made for it, to lessen the angle?
Old Jul 20, 2007 | 07:44 PM
redlude97's Avatar
Ahero removed the perches I believe, put the lower rubber mount back in though
Old Jul 20, 2007 | 07:53 PM
SFLG35's Avatar
FGC President
he just removed the collars
also what aobut the shocks? can they handle that much of a drop? suspension travel? axel angles? raising the diff?
Old Jul 20, 2007 | 07:59 PM
Cost a G's Avatar
yeah..just remove the collars..thats about 1 inch total.
Old Jul 20, 2007 | 08:00 PM
SFLG35's Avatar
FGC President
the collars are only goin to get about an extra 1/2" they arent that thick.
i could remove them and then not put the bottom rubber mount in
Old Jul 21, 2007 | 10:16 PM
SFLG35's Avatar
FGC President
so no one is running coilovers with no spring perches
Old Jul 23, 2007 | 04:20 AM
sugsss's Avatar
If you are talking about the thick rubber pad that mount's on top then yea i removed it car sit's pretty low without it.
Old Jul 23, 2007 | 09:32 AM
SFLG35's Avatar
FGC President
no what you are talking bout is the bump stop. didnt think about removing that one but not a bad idea. what i am talking about is the gold perch that adjusts the ride height
Old Jul 23, 2007 | 01:16 PM
redlude97's Avatar
I would remove the perch before removing the rubber springmount, it holds the spring centered, without it, the spring may pop out of place, or at least knock against the metal subframe during hard cornering, depending how long the spring is.
Old Jul 23, 2007 | 01:19 PM
SFLG35's Avatar
FGC President
yeh i didnt really want to remove the rubber bump stops due to them holding the spring. the tein basic springs are 90mm springs.
Old Aug 14, 2007 | 09:49 AM
izmir41500's Avatar
G35driver Addict
dan, you ever figure this out?
Old Aug 14, 2007 | 12:12 PM
SFLG35's Avatar
FGC President
no havent gotten to do it yet. been busy with work every day and graduation and now im in missouri for a week, so ill have to get to it when i get back.
Old Aug 14, 2007 | 12:58 PM
GreenGoblin's Avatar
The goblin resurrection
i have been running with no collars never though about the no perches I wanna see what this looks like
Old Aug 14, 2007 | 04:41 PM
izmir41500's Avatar
G35driver Addict
I have the fronts on. Just waitin to see what I want to do with the rear.
be sure to take pics of the install too if you don't mind.
Old Aug 23, 2007 | 11:36 PM
SFLG35's Avatar
FGC President
alright so i finally got everything put back together, and within an hour of finishing the car is now down for the count again.
see here: https://g35driver.com/forums/florida-g-club/174009-so-here-how-my-car-looked-7pm-last-night.html
and here: https://g35driver.com/forums/florida-g-club/174047-so-here-how-my-car-looks-now.html
anyways, i decided not to run without the perches. if i were to do that im pretty sure i would be close to tucking rim. right now i am tucking tire, and have about 1.5 to 2 inches of tire showing and the perches are about 2 to 2.5 inches tall so yeh. i can barely make it out of my complex as it is now, so the car wont be goin any lower for a while.
the order from top down goes. rubber upper mount, spring perch no collars, spring, lower rubber mount.
here are some pics if you dont want to check the other threads, these are before driving around and gettin them to settle alittle and even out.
driver side this morning after driving around. it appears to have settled about another quater inch
KruZZe
Feb 27, 2023 05:04 PM
DRG35R
Jan 31, 2016 07:14 AM
Learned Hand
Oct 1, 2015 09:02 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
