TEIN inner and outer tie rods
Old Oct 26, 2007 | 09:37 AM
Hi-TechG35's Avatar
Post TEIN inner and outer tie rods
So my car was having this funny vibration that I know all to well when you have a lowered vehicle. So Monday I raised the car up on the lift and turned my right rim to see if it would move and boy oh boy did it . I did it on the left rim as well and got the same result. Usually driving at speeds between 55mph and 80mph I would get this slight vibration in the wheel. I had recently gotten my rims balanced and a wheel alignment but that did not seem to solve the problem. So I ordered the TEIN inner and outer tie rods which cost me 205.00 for both sides and had them next day aired for an extra 55.00. They got here yesterday afternoon and I headed off to my cousins shop to install them
The old tie rods were done ! There was so much play in the jonit that I was surprised it didn't snap. The TEIN tie rods are definately worth the money . Even though I still have to go get an alignment which i will be doing today, there is quite a noticeable difference in the stability when driving, especially when turning. The tie rods are way thicker than the OEM ones so the chances of breaking or bending one is reduced a lot. The tie rods can also be set to increase the steering angle.
Old Oct 26, 2007 | 11:38 AM
waijai's Avatar
i.love.gold
That's cool...are they G35/350Z specific parts?
Old Oct 26, 2007 | 01:29 PM
Hi-TechG35's Avatar
^ Yes they are.
Old Oct 28, 2007 | 12:51 PM
WILLIE BEANS's Avatar
niceeeee
what are the actual part #'s for
the parts you purchased
and where did you purchase them from .??
thnx . awesome find ..
Old Oct 28, 2007 | 05:34 PM
Hi-TechG35's Avatar
Part numbers are TRS01-P2410 for the inner tie rods and TRS01-P2420 for the outer tie rods. I ordered them trhough a local shop here in Boston.
Old Oct 28, 2007 | 05:37 PM
shadyg35's Avatar
would it be the same part for a sedan?
sorry if its a dumb question
Old Oct 28, 2007 | 06:18 PM
fortified's Avatar
I take it those rods work on stock applications?
You say you ordered them for Both Sides? But not both ends, (F&R) I take it.
When I had my alignment done last month (and toe in again readjusted
after 6 mos) my mechanic said the stock ones are like toothpicks.
Old Oct 29, 2007 | 11:43 AM
Hi-TechG35's Avatar
Yes they would be the same part number.
I ordered both inner and outter tie rods fro the front. We don't have tie rods in the rear. The stock ones are no where near as good structural quality of the TEIN tie rods. There is a notciable difference when comparing the OEM ones to the TEIN.
Old Oct 29, 2007 | 12:22 PM
fortified's Avatar
My bad! The toe in at the rear is set with the radius arm along with other adjustments. Although those are available for after-market too.
thanks for the info! Nice upgrade.
KruZZe
Feb 27, 2023 05:04 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
