Rear sway bar only
Old Mar 2, 2008 | 08:32 AM
GBoy's Avatar
Rear sway bar only
Was wondering if any of you guys installed only the rear on a sedan
and what was the outcome..
GBoy
Old Mar 3, 2008 | 06:57 AM
GBoy's Avatar
Anybody??
Old Mar 3, 2008 | 10:53 AM
Q45tech's Avatar
Normally oem springs are set so that the front is a little stiffer [3-10%] than the rear even adjusted for weight ratios......to fine tune the undulation ratio on highway as the tires roll over seams.
Factory front sway bar is set to create safe understeer, thanks to rubber mounts and bushings this understeer increase progressively as the body rolls.
Remember the sway bar acts just like a spring when the body rolls so, your question really is what happens when the TOTAL rear roll stiffness exceeds the fore aft weight ratio..............assuming identical tires the car begins to oversteer. The more rear power applied, the more the car understeers.
Old Mar 3, 2008 | 01:27 PM
shabarivas's Avatar
Mad Oversteer
Old Mar 3, 2008 | 04:14 PM
GBoy's Avatar
Thanks Q45 for your response, I read what you mentioned in March 06
so was a bit confused..
To save money [and work] just buy a rear only 3 way adjustable and leave front alone. Set it on medium and proceed to the next project.
Old Mar 3, 2008 | 04:17 PM
Jeff92se's Avatar
Red Card Crew
I'd get a set that includes both bars. Much better. And considering I've seen used sets go for $200-$225, there's no reason not to.
Old Mar 5, 2008 | 07:01 AM
GBoy's Avatar
I know some owners just put on the rear 350Evo bar, I just can't
find them with the search...
Old Mar 5, 2008 | 06:37 PM
obender66's Avatar
I use rear only-at medium setting. Works very good. I used front aftemarket as well, but switched back to stock due to unbearable clunking and ride quality. Pretty much no degradation of handling after switch.
Go for rear only and spend other $150 on GT spec bars.
Old Sep 17, 2009 | 05:27 PM
4mermarine's Avatar
I REALLY hate digging up this thread from the dead, but I did the rear only with the 350evo and it greatly improved the rear end for just over $100. I plan to only replace the front sway bushings and stick with the stock bar because everything I've read says it's beefy enough as is. I guess you'd get the adjustability with an aftermarket one, but if you're not tracking I say just replace the bushings with Prothane.
Old Sep 18, 2009 | 09:44 AM
idrive_MD's Avatar
Going with a rear bar only is what the Audi A4 guys (B5 generation) commonly did from what I recall while owning one and browsing the boards. Obviously, it might be something to get used to, but it should provide more controllable oversteer as opposed to OEM tuned understeer.
Old Sep 18, 2009 | 03:49 PM
DaveB's Avatar
I've got the rear bar only (Cobb bar, rebadged Hotchkis piece) as well and it's worked out great. I keep the bar at it's lowest setting which is still about 65% stiffer than stock (I believe). I don't notice any twitchy behavior or snap oversteer. I've auto-xed with the bar and the car is very neutral and I can still send the car into terminal understeer if I get too greedy with the steering input at sub 30mph speeds. Obviously, I can coax the back end out as well, but it's entirely controllable and catchable. Many cars aren't as forgiving. Right now, I see no need for a front bar. The front does exactly what I want it to.
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
TreeFiddy
Aug 10, 2015 06:50 PM
wuppiedog
Aug 7, 2015 11:16 AM
