Rotors
Originally Posted by nghiars
you have to removie the caliper 1st by removing two bolts then the rotor should come right off... irotors are gonna squeak after some use.
cuz i just bought some....
For some reason i don't think removing the caliper alone will enable him to take the rotor off. Remove the caliper, then there is a bolt on the rear side of the rotor. Good luck breaking it loose. I've tried 2 times and will give it one more valiant try before having the dealer replace all corners
03 G35 Coupe
http://www.nicoclub.com/articles.php?id=220764
So the large bolt on the back of the rotor i do not need to loosen? Once the caliper is removed i should be able to "pull" the rotor off?
Once the caliper is off, you can take off the rotor. If it won’t come off by hand, use that 12mm bolt supplied on your OEM rotor. Simply screw it in and start tightening it. It forces the rotor away from the hub and you’ll feel it POP off. Then simply remove the rotor.
There are no other bolts, holding the rotors on. Once you remove the caliper and caliper bracket, the rotor should come right off. It is possible the rotor may be a little "weathered" and may take some persuasion. The bolts in question are the two larger bolts holding the caliper bracket to the spindle, not just the two small bolts holding the caliper in place.
Thanks for the input.
Are you saying that since i have taken the calipers off and changed my brake pads before i was seconds away from removing the rotors?
Looking at the photo i can see that there is nothing holding the rotor into place now. The large bolt i was trying to get at is circled in yellow. Looks like i will give this another go ahead when the weather is nice.
Thanks for the help again!
The left diagram, shows the two bolts holding the caliper bracket in place. YOu do not have to remove these to change teh pads however, only if you are pulling the rotors. To change pads you can remove the lower caliper slider pin and flip the caliper up to access the pads.
You will get a thousand differnet answers. Depends on what you want and plan to do with teh car. If your looking for all out performance, track days etc, you should look at a BBK from a reputable compnay, Brembo, Stoptech, Racing Brake, etc. If you just want loooks, you could go with stock size replacement rotors, from some of the same companies. Satop tech offers a nice package with slotted rotors, lines and fluid. A thrid option is a OE caliper BBK, from some on like Racing brake, larger rotors with stock calipers. I personally chose the Racing Brake OE BBK, and I have now ordered 4 pot calipers to upgrade the front, using the rotors from the OE BBK. Other than upgrading to 4 piston calipers, at a later date, the OE BBK doesn't really have a huge performance advantage over quality stock size replacement rotors. The slight advantage comes from a larger heat sink, and a slightly longer torque arm. Of course a 13 inch rotor looks impressive behind a larger wheel.
So all in in all your options are wide open.
my bro and my buddies have had iRotors on their cars and after about 1 year or 2, they started to squeak...
