Brake bleeding. Perferred method?
Old Apr 4, 2008 | 02:30 PM
Jeff92se's Avatar
Red Card Crew
I've done pump, pressure (slow) and vacuum.
You have have a preference as it pertains to your G/Z? One work better than another?
I have a vacuum type like this: (removed bleeders and put teflon tape on the threads though)
I've also made my own pressure type like this:
Done all three types on my maxima. All worked okay.
Old Apr 4, 2008 | 02:34 PM
EricIsKlumzyee's Avatar
Take off the wheels. take off the little caps.. i think its like a 8 mm or something.. and just suck out the brake fluid.. you want to start from the longest line
I think ours proceedure is
Right Rear
Left Rear
Right Front
Left Front
keep doing it until the fluid is clean then simply tighten the nut.. Oh and make sure you dont run out of brake fluid in the reservoir.
Lastly.. brake fluid will lift your paint if left on the paint which is why i remove the wheels lol
oh and put a big black trash bag under your work area so you dont stain the floors either =)
Old Apr 4, 2008 | 02:35 PM
or if you have two people u can do the pedal method =D
Old Apr 4, 2008 | 02:37 PM
TURBOTOM's Avatar
a.k.a kleicoupe
I'm going to do this next week, I need to flush the lines too?
Any other things that need to be done
Old Apr 4, 2008 | 02:39 PM
Jeff92se's Avatar
Red Card Crew
If it's been more than a year, I'd flush the fluid, yes.
Old Apr 4, 2008 | 02:46 PM
TURBOTOM's Avatar
a.k.a kleicoupe
I think I need 3 pints to flush the fluid right?
I'm going to get motul fluid, whatever the best one is.
Old Apr 4, 2008 | 02:50 PM
Jeff92se's Avatar
Red Card Crew
Quart and a 1/2? If you have done it before maybe. I'd buy more if that motul comes in a storable container. The worst thing is running out.
I'd buy 2 quarts.
Old Apr 5, 2008 | 03:53 PM
KevinE's Avatar
All I know is speedbleeders r fawking AWESOME. They definitely SAVE TIME. Its almost TOO easy to bleed with those things...
When I bleed brakes, I start with the brake furthest away from the master cylinder and work my way up to the closest. Basically what Klumzee said...RR, RL, FR, FL.
Old Apr 7, 2008 | 11:59 AM
Jeff92se's Avatar
Red Card Crew
Anyone even try these methods?
Old Apr 7, 2008 | 12:35 PM
redlude97's Avatar
I've always used the 2 person pedal method and had no issues
Old Apr 7, 2008 | 12:43 PM
JOKER's Avatar
CLUB MODERATOR
I use a pedal method also.
But I was at les schwab recently and they did brakes on one car and their pedal method looked strange to me.
What I do is
One person in the car pumping and I'm outside releasing the fluid.
1. Pump 5 times or till the pedal gets really hard.
2. Hold the pedal
3. Open valve to drain the fluid
4. Close valve
5. Pump the pedal again, hold and repeat.
What they did was
1. Open valve
2. Push pedal once
3. Fluid drains
4. Close valve
5. Release the pedal
Wait a little and repeat.
^this seems weird to me.
Old Apr 7, 2008 | 05:46 PM
clutchless's Avatar
I think that is to replace brake fluid when you do not have to bleed much air out of the system, just replace the fluid. No need to pump the pedal much. Easy and quick.
I use the Mityvac system because it allows one person to bleed the brakes, works quickly and does the job very well. I used the Motive pressure for a couple years ( before I had the G), but had problems getting it to seal on the master cylinder and most of the fluid would pour out on the floor by the engine. Even their screw top exact fit did not fit well and their universal top was a disaster. I will sell it cheap!
Old Apr 7, 2008 | 06:49 PM
Jeff92se's Avatar
Red Card Crew
LOL. I made my own pressure bleeder and yeah, the top wont' seal sometimes. The Z guys are going to get a nasty surprise one of these days. The fluid won't stop pouring out until the fluid is gone or the pressure goes to nil. IMHO there aren't enough threads on the MC to allow a good seal.
Old Apr 7, 2008 | 08:10 PM
GGRJR's Avatar
Actually the factory service manual, says to first disconect the VDC control, or unhook the battery, and then bleed in the following order, rt rear, then left front, , left rear, and fnally the rt front.
Old Apr 8, 2008 | 10:08 PM
jared2027's Avatar
Are you able to rent these from somewhere? Would be nice to not have to buy one when I do mine.
