Help with E-Brake
Old May 1, 2008 | 03:25 AM
MixturePinoy's Avatar
Help with E-Brake
My ebrake is loose I think.. I had my rear on ramps and when i engaged the ebrake, the car moved off of them... NOT FUN! How do I tighten them? I heard it's pretty simple..
Old May 1, 2008 | 03:35 AM
redlude97's Avatar
effin noobs
https://g35driver.com/forums/brakes-suspension-diy/174515-diy-parking-brake-adjustment-05-6mt-sedan.html
Old May 1, 2008 | 03:40 AM
ahem.. i'm sorry, i meant to say for an 04 5AT, since I've alreadt found this one
Old May 1, 2008 | 03:43 AM
hai109's Avatar
Same sheit...you just need to know how to remove the AT stuff...If you don't know then take it to someone that can...haha,
Old May 1, 2008 | 03:45 AM
WTH???? (What the Hai's??!!) LOL
Old May 1, 2008 | 03:47 AM
hai109's Avatar
Double teaming you...hahha...
Old May 1, 2008 | 03:50 AM
redlude97's Avatar
The concept is the same though, anyone should be able to figure it out just by looking at the AT footbrake mechanism for less than a minute
Old May 1, 2008 | 03:54 AM
hai109's Avatar
oh my bad...foot brake...um...very easy sheit...I can't believe you are asking this you noob....hhaha....JK...
Old May 1, 2008 | 09:36 AM
waijai's Avatar
i.love.gold
You can adjust the shoes in the back...pretty easy.
Old May 1, 2008 | 10:40 AM
I don't have to mess with the cable tightening thing?
Old May 4, 2008 | 01:28 AM
n1cK's Avatar
G35 6MT
if you're at the point where you need to adjust, you should check your shoes.
Old May 14, 2008 | 07:41 PM
KevinHeld's Avatar
The ebrake should be adjusted both at the handle/pedal and at the wheels. I'm sure you can just tighten the cable that goes to the pedal, but if the shoes aren't even, you will just end up with the brake applied on only one wheel. The adjustment at the wheels should be the same and you can probably figure out the foot pedal. Also, I remember the factory shop manual explained the AT well. (somewhere on g35frenzy.com)
Old May 14, 2008 | 07:43 PM
Yea.. i don't have the manual... i really should take care of this soon... my car acts really funny when it's on ramps...
Blindside360
Sep 18, 2015 09:00 PM
bflemi3
Aug 3, 2007 09:42 AM
sonicjai
Jul 17, 2007 03:35 PM
G35Dreamz
Dec 6, 2006 02:19 AM
MEECHIN
Jun 23, 2006 12:56 PM
