Strange VDC acting up issue
Old Jun 10, 2008 | 08:01 PM
releasedtruth's Avatar
I'm sure it's been like this since I bought it, but I only really notice it recently. (Only got it 2 months ago). When I'm on an offramp, even if it's a slight curve, the vdc auto brakes and gives me the classic grind and I swear there's no way I'm slipping and if so, I can't tell why. Brand new tires in the rear and good tread up front. I can't imagine the car does that poorly tractionwise, my 94 super coupe slipped less. Happens even on normal roads with a slight turn at 45+ mph. Thoughts? Problem or common?
Old Jun 10, 2008 | 08:11 PM
MikeYo's Avatar
Problem.... My vdc doesn't engadge unless the car is sliding or I take a corner and step on it.
Old Jun 10, 2008 | 08:13 PM
dieselaznrock's Avatar
hey released truth, I dont know the answer but I've read ALOT of threads on this forum about that. try to do a search. It might take a while, but I think its worth it. Honestly, there are alot of threads with this same question. I think most people just took it into the dealership and i dont remember what happened but take a look. hope that helps.
Old Jun 10, 2008 | 09:33 PM
I took a look at a few, but haven't found a thread with results yet. I'll keep looking, but it's good to know it's unusual.
Old Jun 10, 2008 | 09:55 PM
Okay, I have a few things to look at. Rear tires are new so it could be:
- Low brake fluid
- New rears not broken in yet (unlikely) Pilot Sports up front, Falken FK452 rear
- VDC just plain sucks in general
Old Jun 10, 2008 | 10:36 PM
MikeYo's Avatar
Noooo....VDC kicks ****. It's saved me many times. I dont understand why people would want to disable it.
Old Jun 11, 2008 | 12:09 AM
It does no such thing. It kicks in when it shouldn't and that's unacceptable, especially for what's supposed to be at least a higher performance machine.
Old Jun 11, 2008 | 01:44 PM
G35fromPA's Avatar
Different tire brands (which means different treads and compounds) front to rear is your culprit. Stick to the same brand and type f/r.
Old Jun 11, 2008 | 03:35 PM
I'll be on all Falkens soon enough once these Pilots gasp their last, but I hope that clears it up.
Old Jun 11, 2008 | 03:45 PM
mIKE's Avatar
+1
Make sure the tires are the same brand. Different tread is okay; VDC will not kick in agressively unless there is a SIGNIFIACNT difference in the tires.
Also, check your suspension, brakes, lugnuts, alignment, everything. Everything has to be almost spot-on with factory spec for VDC to work the way it is supposed to.
Old Jun 11, 2008 | 08:34 PM
Very good to know Mike. I'll turn it off for the time being, dry roads here in Tucson for the time being
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
03sedang35
Aug 29, 2015 07:56 PM
JMSABO
Aug 4, 2015 11:58 AM
