Guys with BC coilovers - need help!!
Old Feb 21, 2009 | 10:54 AM
  #121
eurodre's Avatar
how r u guys enjoying ur ride quality with the bcs? im pretty low just about 4 inches off the ground at the stock sideskirt and eh lets say u can feel a lot more and the dampenings are at 29 all around
Old Feb 21, 2009 | 11:01 AM
  #122
SFLG35's Avatar
FGC President
im still enjoying mine.
i have 14 12 spring rates and am about 3-4 inches from the ground. my dampening is set at 15 front and 20 rear. its a pretty good ride.
maybe soften yours up some if its a little bumpy for you. 29 is pretty high try 15-20 or so.
Old Feb 21, 2009 | 11:16 AM
  #123
eurodre's Avatar
isnt it 30 the softest?
eather way i turned towards soft and went 1 before the max soft
my spring rate is 8/10
Old Feb 21, 2009 | 11:21 AM
  #124
SFLG35's Avatar
FGC President
yeh could be.
10f 8r spring rates should be pretty good. but you should feel more like you said in your first one because the spring rates are def stiffer than stock and the shocks are valved a little more aggressively.
how did you lower the front? did you change the preload on the spring? or adjust it at the bottom?
i have found that some people are lowering it by changing the preload on the spring in teh front and not at the bottom bracket.
my it is a 14f 12r and i keep it at 15 down from full hard in the front and 10 down from full hard in the rear.
Old Feb 21, 2009 | 11:24 AM
  #125
eurodre's Avatar
naw i know that 1 i know not to touch the front preload, i lowered it by the very bottom ring i know that 1, iv been in cars that r low before so its not like im new to it, i wus just really suprised, cus i know 10/8 spring rates give the best ride comfort out of the line up, right?
Old Feb 21, 2009 | 11:27 AM
  #126
SFLG35's Avatar
FGC President
yes the 10 8s would be more comfortable.
good good on the rings yeh ive been gettin people asking me about it and when they were installing and messing it up, so i was just checkin.
is it too stiff for you? i can maybe see about gettin you an 8 spring for the front if you would like. pm me if you are interested
Old Feb 21, 2009 | 02:24 PM
  #127
dkhuynh's Avatar
I'm running 10/8 with the struts set to 13 all around and it feels comfortable.
Old Feb 21, 2009 | 03:46 PM
  #128
eurodre's Avatar
^^how low r u tho?
Old Feb 21, 2009 | 03:53 PM
  #129
dkhuynh's Avatar
gonna go lower
Old Feb 21, 2009 | 04:09 PM
  #130
eurodre's Avatar
damn that looks good
Old Feb 21, 2009 | 04:55 PM
  #131
dkhuynh's Avatar
yours look sexier
Old Feb 21, 2009 | 05:01 PM
  #132
eurodre's Avatar
lol wut?
Old Feb 21, 2009 | 05:06 PM
  #133
dkhuynh's Avatar
the drop
Old Feb 21, 2009 | 05:11 PM
  #134
eurodre's Avatar
best pic i can take for now, doesnt look as low cus i threw on some 25mm spacers
Old Mar 3, 2009 | 12:05 AM
  #135
Z_IP_G's Avatar
eurodre is that the lowest it can go for the front and back or can you still go lower? btw, the g looks good.
