Relentless Autosports Strut Bar - (NOT VRT!)
Mar 25, 2009 | 04:06 PM
  #706
Quote: I don't think GTspec manufactures this for Scott. Their bar is shown here. http://shop.edoperformance.com/gtspe...n-p-12280.html
It is 1 of only 5 though...
The ones from this group buy were definitely made by someone else.
Mar 25, 2009 | 04:17 PM
  #707
Quote: From my experience, for the absolute best fitment, putting a car on jacks is recommended but as far as MANDATORY just for it to work, that's debateable.
Umm no, putting the car on stand is just cause for body flex, how can you get best fitment like that. For best fitment your car should be on the ground on a leval surface!!! I have never heard of anyone putting a car on stnds to install a strut bar!!!
Mar 25, 2009 | 04:23 PM
  #708
Quote: Umm no, putting the car on stand is just cause for body flex, how can you get best fitment like that. For best fitment your car should be on the ground on a leval surface!!! I have never heard of anyone putting a car on stnds to install a strut bar!!!
The best way to get it to fit properly is to modify your car to fit the RA strut bar,... not the other way around.
Someone suggested using a jackhammer, I think an arc welder will work just as well.
Mar 25, 2009 | 04:24 PM
  #709
I personally have never done it. I asked my co-worker Mike (he's on the GT-R forums) and that's what he said. So sorry for the confusion. IMPE, I've done it on the ground.
Mar 25, 2009 | 04:30 PM
  #710
FWIW, putting a car on jackstands reduces the forces on the shock towers which cause them to flex inwards slightly when on the ground. This is what a properly designed strutbar is meant to prevent
Mar 25, 2009 | 04:35 PM
  #711
Quote: The best way to get it to fit properly is to modify your car to fit the RA strut bar,... not the other way around.
Mar 25, 2009 | 04:55 PM
  #712
Currently Active Users Viewing This Thread: 9 (5 members and 4 guests)
BulletproofG35, captj3, ToastZ, XKR, hound138
LOL @ the pack of hungry wolves.
Mar 25, 2009 | 05:06 PM
  #713
Quote: FWIW, putting a car on jackstands reduces the forces on the shock towers which cause them to flex inwards slightly when on the ground. This is what a properly designed strutbar is meant to prevent
You mean to tell me that nissan doesn't know how to design a car? The strut bar is to stiffen the car under load not when parked. The truth is the car doesn't need it. Look at a 350z which is for the most part is the same as a G35. It doesn't need to be put on jack stands for any strut bar to be installed no matter who made it. I hope for the sake of the people that bought one scott makes good on sending out the right replacement parts to correct the problems. It's absurd to have to modifiy any of his parts. He should fix the jigs that were used to make them.
Mar 25, 2009 | 06:24 PM
  #714
It's not surprising that the strut bar fits like crap. Look at the terrible quality in welds and how the pipes are bent with varying angles.
Anybody that would pay $500 for that garbage is a complete idiot. Look at the crappy welds on those things. It almost reminds me of the ugly "roll cage" they did in that yellow VRT car with the truck style "push bar" in the front rofl. Lord have mercy they destroyed that z.
Mar 25, 2009 | 06:33 PM
  #715
Mar 25, 2009 | 06:40 PM
  #716
Quote: You mean to tell me that nissan doesn't know how to design a car? The strut bar is to stiffen the car under load not when parked. The truth is the car doesn't need it. Look at a 350z which is for the most part is the same as a G35. It doesn't need to be put on jack stands for any strut bar to be installed no matter who made it. I hope for the sake of the people that bought one scott makes good on sending out the right replacement parts to correct the problems. It's absurd to have to modifiy any of his parts. He should fix the jigs that were used to make them.
Have you ever even heard of preload? If the bar is meant to be installed with the car on jackstands as described, then the design maybe was built with pretension between the shock towers so that when the car sits on the ground the the bar is already flexed, much like the design of the OEM 350z bar with its adjustable endlinks
Mar 25, 2009 | 06:59 PM
  #717
Quote: ^yes, i have spoke with him on the phone several times and he only told me its probably my car and that i should try and bend the bracket down. Brought it to 2 shops, both said they wouldn't try to bend that bracket and a new one should be made. I just finished up writing him an email with these pictures giving more detail of the problem and the corrections that need to be made to the passenger side bracket. He said on the phone he will be able to send me new bracket once he sees the problem im having.
I spoke with another member on the forums who bought this bar years ago from Scott and said he had the same exact problem with the passenger side bracket and had to get a new one made for him. I'm just wondering why the hell did I not read anything about all of these problems before i forked over $500????
That bar is sitting about 1/2 inch higher than my original "VRT" bar. My bar has about a 1 mm gap between the wiring over the timing cover. Your bar looks a good 1/2" above the wire loom.
I don't think this is a difference between cars Scott. This is lack of consistency in your manufacturing process.
Mar 25, 2009 | 07:29 PM
  #718
Damnn this thread been going on forever. So RA has a strut bar?? I didnt know this, any good or bad reviews? lol..damn im so late into this hahahahahahha
Mar 25, 2009 | 07:39 PM
  #719
Quote: Damnn this thread been going on forever. So RA has a strut bar?? I didnt know this, any good or bad reviews? lol..damn im so late into this hahahahahahha
not many functional reviews... just mostly regarding fitment issues...
However, there were a bunch of pseudo reviews before people even ordered them (from people that didn’t have one)
Mar 25, 2009 | 07:41 PM
  #720
^ It doesn't matter anyways... I don't think it'll fit an 08 G37...
