Removing Rotor
Old Aug 30, 2008 | 09:07 PM
jhurst's Avatar
Removing Rotor
I have a missing stud and I have tried to remove the rotor now twice unsuccessfully. I have tried hitting the ever-loving **** out of it for 15 minutes solid with no luck (and yes I have removed the caliper). This is a front rotor, is there anything else I can try and do?? I am going to pull out all of my hair over this.
Old Aug 31, 2008 | 01:37 AM
G35sedan03's Avatar
like the rear rotor, it has two screw holes on the hat. find a screw that fits that hole, usually the bolt that holds the calipers on fits in there. that should be it. it's just rusted tightly.
Old Aug 31, 2008 | 04:19 AM
KSWAY's Avatar
Your rear rotors on your G has 2 holes in it?
Old Sep 1, 2008 | 01:39 AM
spinn's Avatar
I used a bolt from a steering wheel puller to screw (push) out the rotor. There is only one hole on the OEM rotor.
Old Sep 1, 2008 | 01:49 PM
5150DS's Avatar
Did you try penetrating oil like Astroglide.
Serious about the penetrating oil though, something like WD-40.
Old Sep 1, 2008 | 02:35 PM
Infinite_R's Avatar
Yaaaah Yaah Trick!!
Are there any brake specail tools need to change out rotors. I noticed the big nut in the center of the rear rototr.
Anyone have a link for a how-to on this? I'm still trying to figure what I need to do to get the calipers off.
Old Sep 1, 2008 | 04:41 PM
5150DS's Avatar
You just need the right size socket and a breaker bar for the calipers. There is a thread somewhere on here on doing brake service, I will see if I can find it.
Edit: I found it, there are alot of DIY videos here by BYTHEBAY: https://g35driver.com/forums/faq-diy...eo-series.html
Old Sep 1, 2008 | 05:00 PM
jhurst's Avatar
Where would I squirt the WD-40 on the rotor? Back, front, in the stud holes?
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
alinero718
Sep 27, 2015 09:35 PM
