Z H-tech on G?
Old Sep 4, 2008 | 12:38 AM
Ching1206's Avatar
Z H-tech on G?
im ready to lower my car a bit...
planning to get Z's Htech
says that
"Tein H-tech 350z linear springs .3”/.2” drop on 350Z G35 drop will be higher
Spring rates in LBS 358/375 "
so those on G coupe gives a .5 more drop right??
so its .8 front n .7 back...
with that i dont need a camber kit right???
but when it settles down...will it go lower than 1inch???then will i need camber kit?
Old Sep 4, 2008 | 12:52 AM
bigc's Avatar
Wings Nation
- yes, they'll lower the coupe just under an inch.
- some people think the drop is uneven so they cut the rear springmounts down a little (search spring mount mod).
- you should get at least a rear camber / toe kit. you can get them for as little as $170 new and it will be cheaper if you install them at the same time as the springs.
Old Sep 4, 2008 | 01:08 AM
Ching1206's Avatar
I dont get the UNeven part???
which uneven...??
Left n Right??
Old Sep 4, 2008 | 01:11 AM
bigc's Avatar
Wings Nation
front vs. rear
Old Sep 4, 2008 | 01:15 AM
Ching1206's Avatar
i dont get it...
shouldnt the front lower than rear???
Old Sep 4, 2008 | 01:17 AM
bigc's Avatar
Wings Nation
if you search around on this topic, you'll note most people end up with the rear sitting noticeably higher than the front. the solution is to cut down the rear spring mounts - again, search for 'spring mount mod'
Old Sep 4, 2008 | 01:24 AM
Ching1206's Avatar
aite aite
thanks fo the heads up...
Popes
Jul 29, 2015 05:07 PM
haze
Apr 6, 2005 07:39 PM
neffster
Jan 21, 2005 11:03 AM
g8tor20
Dec 13, 2004 07:33 AM
skysky
Oct 30, 2004 01:04 PM
