Where Could I get my Rotors Painted
Old Oct 1, 2008 | 05:23 PM
FlameOn's Avatar
Where in SoCal can I get my rotors painted? I really don't want to do this myself. But I would like to get rid of the rust on my R1 Concept rotors?
Any members out there willing to do this either?
Old Oct 5, 2008 | 11:17 PM
Engineerseller1's Avatar
YOU CANT PAINT YOUR ROTORS!!!!! Your brake calipers if thats what you mean....
Old Oct 6, 2008 | 01:00 PM
Nate76s's Avatar
You can paint your rotors center hats, but that is it.
Old Oct 9, 2008 | 07:56 AM
sorry for that....
Your correct nate... You can paint the center hubs but not the actual surface where the brakes will be rubbing!!!
Old Oct 9, 2008 | 10:46 AM
idrive_MD's Avatar
Its extemely easy to do, see my step by step process in this thread below:
https://g35driver.com/forums/brakes-...se-rotors.html
Old Oct 11, 2008 | 06:23 AM
Gilley's Avatar
You can certainly paint the rotors. It's easy to do yourself. Clean them first and use a light enough coat to cover the bare metal but don't put too much paint on them. Use high temp paint from the auto parts store. The pads will immediately remove the paint where they contact the rotor. That way, the entire rotor is protected except for the pad contact area. Just make sure the paint is dry before installing the rotors.
Old Oct 28, 2008 | 06:53 PM
caltender's Avatar
Painted my calipers and rotors last week
Turned out pretty good IMO
Old Nov 18, 2008 | 08:30 PM
Varsity Tyler's Avatar
psh ..... light coat of paint on the rotors wont hurt at all. the pads will just wear the paint off after one or two brake applications, leaving the hat and the lip all pretty.
i've done it to numerous drilled rotors. do it with a heavy primer and it does a fantastic job of preventing rust from escaping out of the holes.
just don't go nuts and give the thing five coats. all you want it to do it to prevent rust. and take 'er easy for those first couple stops.
seagrasser
May 3, 2022 09:43 AM
awalle01
Sep 28, 2015 12:36 AM
alinero718
Sep 27, 2015 09:35 PM
