Compression rod / Lower control arm ... little confused HELP
#61
is it worth it to just get the bushing and have them pressed in or i mean you can go to oreily's and get a entire new lower control arm for $100.99 each.. and those have "Limited Lifetime Warranty"
Link for left one
Link for right one
Oh and also if i were to buy the bushings and i need to do both sides of the car, do i need two sets? or will 1 pack do me good? thanks. lots of good info
Link for left one
Link for right one
#62
#63
An only necessary for one and alignment at owners discression.
#67
Unbolt sway bar end link (remove from LCA), remove shock mount retaining bolt, unbolt from steering knuckle ball joint then unbolt from chassis. In that order.
Replacement is easiest if you replace ball joint position and shock mount position first, then use a thin chisel or a very strong screwdriver to insert thru the chassis and bushing to line up the bushing with the hole in the chassis. That way the bolt will go thru. Rebolt at chassis position, then of course tighten sway end link.
yassy (05-02-2015)
#68
No picture needed.
i looked underneath, how did you get to bolt on chassis. looks hard to get to.
also where is best place to get new one? Saw one on ebay for 219. thanks
#69
Also helps to have a gooseneck wrench to hold the bolt on the backside.
rezendvous420
05-31-2020 01:26 PM
keithk831
Steering & Suspension
08-02-2015 09:50 PM
