Best Reliable Camber Kit?
I was going to go with SPC hands down but after researching and seeing all this hassle with spacers and sensor problems, I'm currently reconsidering.
Any experience or advice?
I was advised SPL Front and SPC Back......
SPL seems quite pricey maybe cause they're on a smaller production to SPC, I've only found ART as the only seller?
SPC front camber kits are fine as long as you specify that you are running them on a G35 coupe. SPC used to have only one kit that was interchangeable between 350z and G35 coupe, and that was what caused the ABS sensor knocking.
Now there are two seperate camber kits each with their own item # designed differently for each application. Just make sure to order the right one and you won't have any problems.
I've been running SPC fronts for half a year now, the shop didn't even have to install the front spacers. No problems at all.
I have SPC fronts and rears. I also have the front knocking issue. From what I've researched, it only appears to be those with a more aggressive drop that suffer from the knocking issue. I have the revised front arms as well.
I never installed the spacers or ABS bracket so I didn't have the ABS light always on issue.
I'll be going with SPL fronts once I save up the cash for them.
if you guys are buying the SPLs wait a few more weeks coz the customer service told me they are releasing a version 2 of the a-arms
heres the email i got
i will be sending them my old ones so i can upgrade. coz the V1's have problems w/ low cars. It hits something when you hit a dip in the FWY or streets when going fast.
My set up right now is
SPL in the front
eibach(SPC) in the rear
We can modify the a-arms for you, if you want to ship it back to us. Just FYI, we are also releasing a new version of the a-arms, that will be stronger/stiffer and have better clearance than the original a-arms, as well as having a better quality ball joint. Existing a-arm owners will have the option of upgrading for a discounted price. So you might want to wait a few weeks and consider upgrading to the new version...
SPL in the front
Im running SPC front and back when purchasing the rear get the eibach kit its an eibach box with SPC bolts and rear arms for a cheaper price
heres the link to my old thread
https://g35driver.com/forums/brakes-...amber-kit.html
kr33p
Steering & Suspension
Sep 7, 2015 11:23 PM
