Need an answer! Ichiba rear camber kit
Old Mar 19, 2009 | 08:28 PM
DanielsG's Avatar
Guys, I am lowering on Eibach sportline springs and obviously need a camber kit. I was really close to buying the ICHIBA kit becasue it costs less. (I know its still SPC) but I was reading up on it and it seems that the toe studs included dont work on it enless I modify it by cutting something..... So is this true? Why would anyone get this if its crap and are unable to adjust to toe to factory spec? Should i scrap the ichiba and just get the Regular SPC?
Thanks
Old Mar 19, 2009 | 10:10 PM
redlude97's Avatar
all toe bolts require cutting the subframe, thats how you get additional adjustment
Old Mar 19, 2009 | 11:34 PM
DanielsG's Avatar
right on thanks..
Old Mar 19, 2009 | 11:37 PM
NaiveRapture's Avatar
But from what I've been told, in many applications you don't need the extra adjustment... just depends on how low you go.
Old Mar 20, 2009 | 12:13 AM
DanielsG's Avatar
im getting the Eibach sportlines. so its pretty low. I may need it. better be safe that where tires out. Bad TOW KILLS tires way more than bad camber.
Old Mar 20, 2009 | 02:36 AM
redlude97's Avatar
If you already bought the parts, why not install them?
Old Mar 20, 2009 | 07:50 PM
It's not like when you buy the camber kit you can buy it without the toe bolts... and just because something comes with a part doesn't mean you have to install it. Elongating the holes seems much more involved than if you just use it how it came. I got mine from b2autosport and he said when they install the rear camber kits they rarely have to elongate the hole for the person to get aligned back to OEM spec's. Why mess with something if you don't have to?
Old Mar 20, 2009 | 08:00 PM
redlude97's Avatar
All SPC/Eibach/Ichiba kits come with the toe bolts. If you install them without elongating the subframe holes, then the adjustment range is still the same as stock. Getting "back to OEM specs" is not the same as getting back to optimal specs. How are they defining OEM specs? As the very edge of the adjustment range? Certainly not what I would consider optimal. I have one of the most conservative drops(Z h-techs with springmount mod) and I wasn't able to get back to nominal OEM specs without the full SPC kit
Old Mar 20, 2009 | 08:51 PM
Honestly I'm not going to debate it any more as I don't know enough about the topic... I got the kit since I was told that I needed it if I dropped my car. I have the springs and rear Ichiba's sitting on my floor right next to me in plastic bags lol
Old Mar 21, 2009 | 12:29 AM
Blackmouf's Avatar
I'm just stepping in to validate Redlude's answers. In order for optimal adjustably, elongating the toe holes is a must. In fact, the SPC installation guides for the toe bolts clearly list that you elongate the holes. In fact, the toe bolt kit comes with 2 square paper cut outs that you use to mark the holes before cutting them.
I wish you well with your install and whatever you choose
Old Mar 21, 2009 | 01:03 AM
So you're saying that if I just install the kit and don't elongate the holes, that when I go to have my alignment done they aren't going to be successful?
Old Mar 21, 2009 | 08:55 PM
DanielsG's Avatar
Yes. The elongation allows for the alignment to be tweeked back to OEM specification. As redlude stated, the elongation will allow for a proper alignment. MY question is i just received my kit, Ibicha rear camber and toe, and didnt receive the templates for the dremeling. where can i get one???
Old Mar 21, 2009 | 08:58 PM
So the kit is pointless without extra modification?l
Old Mar 21, 2009 | 09:11 PM
DanielsG's Avatar
no not pointless because without doing that you can still adjust the camber.
socalg35x
Aug 7, 2015 09:36 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
nascarbuff17
Jul 16, 2015 10:23 AM
