Bushing stuck in rear spindle
Old 04-11-2015, 10:03 PM
clearwaterms's Avatar
Originally Posted by reconJDM
does anyone know how to press the ring out?
my bushing was seize to the bolt and now I require to press the ring out.
so ****ty :\
If anybody else finds this and needs help with how to remove the old bushing and install the new one...
The first thing I did was ripped out the inner section of the lower bushing leaving a little rubber and the sleeve. A careful hacksaw will eventually cut a notch in the sleeve and then using a large socket that was the same size as the bushing I was able to easily hammer it out.
To install the new one I used a threaded rod along with a few sockets..
http://www.superstreetonline.com/how...d-replacement/
With the threaded rod with 2 bolts on one side and a socket on either side I was able to hit the thing with an air hammer until it pushed the bushing into the knuckle.
rezendvous420
05-31-2020 01:26 PM
si_driver
08-11-2015 07:08 AM
TreeFiddy
08-10-2015 06:50 PM
teamghost
07-28-2015 04:52 PM
netcbc
Steering & Suspension CDN
07-24-2015 01:59 PM
Quick Reply: Bushing stuck in rear spindle
