Why does my car feel so sloppy compared to other cars??
Old Apr 13, 2009 | 11:31 PM
Wannabe6MT's Avatar
-MN G Crew-
I test drove an Acura TL 2006 today. That car felt so solid and stable. It was stock BTW.
My dads 08 G35x, solid as a rock.
My car, lowered on Z springs up front, coupe springs in the back with 04 sedan sport struts, feels like a damn boat. Almost like when taking a turn all the weight goes to the front outside wheel.
Would this mean the springs are bad or the struts? i want it to feel solid like our 08 or the Acura i drove today. Its just not... solid feeling.
What would cause this?
Old Apr 14, 2009 | 01:33 AM
Wannabe6MT's Avatar
-MN G Crew-
Nobody have any ideas? Why does my car feel so big have have so much body role????
Old Apr 14, 2009 | 02:44 AM
Cost a G's Avatar
Could be a blown strut. Or maybe you just need stiffer struts.
Old Apr 14, 2009 | 03:05 AM
UR2EZ's Avatar
i think you need sway bars...
Old Apr 14, 2009 | 04:52 AM
Blackmouf's Avatar
sway bars
Old Apr 14, 2009 | 05:33 AM
Dranom's Avatar
get some better suspension and def swaybars!
Old Apr 14, 2009 | 10:47 AM
eurodre's Avatar
get coilovers
Old Apr 14, 2009 | 10:59 AM
RADIOGUY21's Avatar
I would definitely get some sway bars, they will help with the body roll. How many miles did the 04 sport struts have on them when you installed them? Could be bad strut(s). Also are you running the unrevised or revised rear springs? You should be running unrevised so the sport shocks are matched to the correct spring rate.
I have the same spring setup as you, only I am rolling on the sport 18s with 235/45R/18 potenzas, my stock 05 sport struts/shocks and Stillen sway bars. I did the springs mostly for better looks/less wheel gap but the car handles and takes corners alot better. Body roll is significantly less too.
Old Apr 14, 2009 | 01:20 PM
redlude97's Avatar
sounds almost like you just aren't used to a neutral/oversteering biased car. Every TL I've ever driven understeers like a mother
Old Apr 14, 2009 | 02:09 PM
Jeff92se's Avatar
Red Card Crew
Not sure why you would think your car would be handling much better. Z/coupe springs have the same spring rates as the sedan sport. Your shocks are nothing special either.
You're just lowered about 1" / 0.5"
Like Hai said, I don't think you know a well handling car.
Old Apr 14, 2009 | 10:30 PM
Wannabe6MT's Avatar
-MN G Crew-
I might need struts....
Oh yea for sure it understeered. But it stayed flat unlike my car which i can take turns faster, but it just leeeeeeeans.
I remember my car handling like a boat stock too.
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
slider_ua
Jul 29, 2015 04:17 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
Karnicle
Jul 23, 2015 05:08 AM
quickspeed6
24
Jul 15, 2015 11:06 AM
