NEW SPL PRO front compression rod bushings
Rating: Thread Rating: 3 votes, 4.67 average.
Old Mar 4, 2010 | 01:20 PM
Andrei's Avatar
Exclamation NEW SPL PRO front compression rod bushings
It's going to be out!! Estimated release - Mar 31 2010 I emailed them asking about it last year and now it's out. http://www.splparts.com/main4/parts/...tmultilink.htm
Sat, Sep 5, 2009 at 4:27 PM
Do these bushing replace the bushing in the compression rods on the 2003-2006 RWD G35? The stock compression rods bushing have been know to tear and make noise and Nissan has revised the compression rod bushings but I was wondering if the bushings in the SPL complete set replace the ones on the compression rods also. The problems with stock compression rod bushings can be found here. https://g35driver.com/forums/brakes-...l-crap-11.html
Thank you.
Alex C
Hi Alex!
These bushings replace only the lower arm bushings, they do not replace the compression rod bushings. We may have an offering for the compression rod bushings in a few months...
Solid bushing. Will outlast the rest of the car.
Someone please sticky this so people with cars that have the bushing failure can find it easily.
Old Mar 4, 2010 | 01:27 PM
Mustang5L5's Avatar
Bout time. My replacements are holding up fine, but nice to know there's an aftermarket option.
Curious to see if the solid bushing here affects ride quality.
Old Mar 4, 2010 | 01:29 PM
lil_will's Avatar
Interesting.
Old Mar 4, 2010 | 01:32 PM
Andrei's Avatar
I could really care less as long as it corners like it's on rails and has the characteristics of a double wishbone suspension when it comes to tyre wear.
Old Mar 4, 2010 | 01:34 PM
azt108's Avatar
Now I can stop using PB Blaster.
Old Mar 4, 2010 | 01:46 PM
4DGS's Avatar
Ohhhh, when mine go I'm getting these.
ANy idea what they'll charge for them?
Old Mar 4, 2010 | 01:47 PM
Andrei's Avatar
+1^ That creaking noise is kind of embarrassing for a G35. Kind of questionable if it's acceptable for a car that was 35k new. But you get twice the options for an equally priced 3 series.
My guess is less than $100 for a set.
Old Mar 4, 2010 | 01:55 PM
4DGS's Avatar
I hope they don't try and charge out the *** for them, if they don't they are going to sell a tonne.
Old Mar 4, 2010 | 01:59 PM
Andrei's Avatar
I highly doubt they will charge more than $100. The other bushing sets they offer which is more than 2 in a set cost only a little more than $100.
Old Mar 4, 2010 | 02:27 PM
DaveB's Avatar
Just remember folks, there's good reason why OEM bushings are rubber and race bushing are metal. It's called NVH or noise, vibration, and harshness. Anyone purchasing race-style bushing setups should understand the NVH increase (sometimes significant).
Old Mar 4, 2010 | 03:21 PM
Mustang5L5's Avatar
I agree. I've ridden in cars setup for autoX and road racing with spherical type bushings on the control arms and it was a NVH nightmare.
Of course, this is one bushing...but still curious to see the impact. To be quite honest, if it results in noticable harshness, i think i'd prefer to use OEM rubber instead.
Would they sell them as bushings only to press into your stock arms, or the entire arm?
Old Mar 4, 2010 | 03:30 PM
Andrei's Avatar
Bushing only. They have to pressed in. I have access to equipment at a shop to press them in.
Old Mar 4, 2010 | 05:05 PM
OCG35's Avatar
those bushing will do the trick (in terms of wear)...
but like others mentioned - my concern is ride comfort... I sacrifice a bit in general - but until I start using solid mounts, I doubt I will use metal bushings...
$50 every 20K miles or so is no biggie to me...
Old Mar 4, 2010 | 05:20 PM
Mustang5L5's Avatar
So even the replacement bushings are wearing on you?? Great.
Old Mar 4, 2010 | 05:24 PM
Max626's Avatar
Looks good now only if the ball joint were replaceable
You have already rated this thread Rating: Thread Rating: 3 votes, 4.67 average.
