Ceramic Brakes
Ceramic Brakes
Hello all - I have an '04 G35. I have experienced all the typical brakes issues including brake dust and horrific squealing. The dealer replaced the brakes at 23K miles the squealing was gone temporarily. At 41K miles it was time for new brakes again (and front rotors), and I took it to someone other than the dealer for the first time. I told them of my woes, and when I picked up the car and drove out of the lot I noticed a huge difference. The car felt heavier and the brakes were NOT as sensitive as they had always been. I revisited the shop and they informed me that they used ceramic brakes, which would alleviate the dust and squealing (and would last longer) - the trade off would be less "sensitivity" as the metal pads on metal rotors would provide. Has anyone heard of this "remedy" before?
I'm not sure I'm willing to live with the trade-off. (They did my transmission fluids - I'm not sure if anything they did could contribute to the "heaviness" of the car...it just doesn't feel as nimble.) Also, when I brought it back they said there was no air involved in replacing the brakes, so it had nothing to due with air. Any thoughts or suggestions would be appreciated...
If they did your transmission fluid, they should have used Nissan Matic S fluid only. Anything else and you risk part of your powertrain warranty. I'm assuming you have a 5AT. And that heaviness could definitely be related to the fluid they used in the transmission. Put a 50W oil in your engine and it will run, but I guarantee you'll feel a big performance difference. Find out what they put in there.
As for the brakes, yes the ceramic's will not be as noisy, but they also won't stop your car as well as the dusty, squeaky OEM's did. That's the tradeoff. The G35 has one of the shortest 60-0 stopping distances out there, something like 110-113 feet. That's borderline super car territory. So most "fixes" won't be as good as what the car came with, or Infiniti would have already done it.
Infiniti OEM pads actually have some ceramic compound in them, particularly in the rears. Furthermore the OEMs probably aren't going to have a higher heat dissipation rating than aftermarket pads with higher ceramic content. So you won't get any greater fade resistance which is more important than the greater initial "bite".
This is why many people who track their cars have 2 sets of pads, one for daily use and one for the track.
You can't say which is more important without also describing the scenario involved. Greater fade resistance is more important if you're tracking your car, but initial bite is more important for regular day-to-day driving. You simply aren't going to have multiple hard braking situations during regular driving, so better fade resistance has little value. You are, however, going to have singular emergency hard braking situations during regular driving, so that loss of initial bite will definitely come into play. It could be the difference between stopping short and putting your front bumper into someone's back seat.
I am planning on removing these pads and returning to OEM. The OEM pads do have their drawbacks, but for day to day driving, I'm assuming no other pads are comparable in the above said category.
Also, will my slotted rotors fare well with the OEM pads???
What he said.
Are you guys serious? Hawk HPS have given me no problems on 2 different cars. I'm running them on the G right now. Never once had initial bite problems. Not once. It's all about the proper bed in. You don't do it right and they aren't gonna work for you. In case you didn't know, HPS pads are street pads, hence the S in the name. They are a pad centered on doing great on the street and well at the track for the weekend warrior. If you hardcore race, they aren't the pads you want. But if you are a spirited driver these work great. No I don't work for them or get paid by them either. I don't even wear their decals. I've used OEM's, off the shelf pads, and ceramics besides these. None have felt more predictable than these.
I'm not saying the OP needs to get these. The OP is correct that ceramic is not a good choice for the street. I know the Vette comes stock with them as do many other brands of cars. But their suspension and brake systems are engineered with them in mind. Different rotor material, different caliper designs, etc.
The lack of a thorough review on my part, and getting caught in the over hype of these pads is the reason why I ended up with them.
I would really like to find out the stopping distance numbers of Hawks vs.OEM, since so many people feel Hawks stop their cars better.
Maybe some factual numbers would end the mass placebo effect with Hawks!
Although the proper bedding of these pads factors in their performance, I do believe Hawks Hps are advantageous to those that live in warmer regions, such as yourself. Hawks are not best suited for individuals, such as myself that deal with snow, and temperatures that can dip well below 30 degrees. These pads greatly rely on being heated up to temp for optimal performance. One shouldn't have in the back of their minds, "hey this is my third stop light, my brakes should be ready for use". A side from the colder temps, I even noticed that these pads under perform in wet conditions; it just does not grip confidently.
Hawk pads do exactly what they were designed to do. I guess I live where the input conditions for these pads are near optimum and serve me well for what they can handle.
"Hate" is a pretty strong word to describe Raybestos ceramics, which are the very brake pads that come in the Delco box at GM dealerships for Corvette Z06s.
I cannot lock up my wheels if need be..
They are coming off next week, one thing I do give them is no dust and no noise, but I'd rather be safe so going back to OEM..
