which side??? front wheel bearing
Old Oct 20, 2010 | 05:41 AM
jw973's Avatar
Pretty simple question..... I have a front wheel bearing going bad.... I jacked the front end up and neither of the wheels have any play from what i could tell. The car has a light roaring noise going strait, when I turn to the right it gets heavier, when I turn to the left it goes away all together.....
thanks
Old Oct 20, 2010 | 05:44 AM
jw973's Avatar
Oh forgot to mention the speeds that the vibration was at were anywhere from 35-70....
Old Oct 20, 2010 | 03:20 PM
jw973's Avatar
anyone....
Old Oct 21, 2010 | 03:27 AM
jw973's Avatar
just wanted to say thanks to the guys at Riverside Infiniti for helping me out and pointing me in the right direction.... can always count on them....
Old Oct 21, 2010 | 11:14 PM
culi's Avatar
so what was the answer from Riverside? I'm having the same issue too. Replaced the front bearing and still hearing noise. Not sure if it is the same side or the other side.
Old Oct 24, 2010 | 06:52 PM
jw973's Avatar
from what I described to the tech.... it appears I am going to start with the left side... good thing is they are universal. Worst case scenario it could be both...
Old Oct 24, 2010 | 07:51 PM
the_sedan's Avatar
sounds like the left side. alot of times they wont have play in them nor can you feel it UNTIL you take the wheel bearing out and spin it by hand.
Old Nov 5, 2010 | 01:21 AM
Gspald's Avatar
I have a very similar problem with my '04 G35x. Car only has 61K miles. Just put new tires all way around. If any difference it is more pronounced now. From 30MPH and up I hear a humming noise similar to the sound made by the engine fan. As I speed up so does the noise. Purchased car about 5-6 months ago and it appears to have been well maintained. Noise began within last week or so. I can't afford to take it to an Infiniti dealer right now. I suspect the psgr side front wheel bearing. At present I am trying to remove the Hub assembly to check the bearings. Using long breaker bar to remove spindle nut; but can't keep rotor from turning in process. I am sure impact would help but my air compressor is broke. NEED HELP Am I looking in the right direction for the cause and can you suggest how I can remove that nut.
Old Nov 5, 2010 | 01:57 AM
jw973's Avatar
just got around to changing it myself today.... only took about 30 minutes.... the car drives like a new car again..... turns out it was the left side.... thanks to the guys at riverside for hooking me up with the info and a deal on the parts.
Old Nov 5, 2010 | 02:02 AM
jw973's Avatar
Im not that sure about yours with it being the g35x.... sounds like the problem i had though.... id do some searching on the forum. try a search for g35x wheel bearing and i'm sure its a dyi somewhere... the impact should get it off though...
Old Nov 16, 2010 | 04:44 PM
empirion's Avatar
Want your broken wheel hub
are you willing to ship the old broken hub?. i need the ABS ring off of it. I'll pay for shipping and extra for your time. Thanks
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
rping
Jul 26, 2015 09:53 PM
itschuckster
Jul 25, 2015 08:07 AM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
