Energy Suspension Front End Kit Installed!
Old Sep 9, 2011 | 07:32 PM
  #31
brandon1978's Avatar
[QUOTE=datbeans;6104206]are the bushings surpose To sit this way?
Mine look the same. Also taken with wheels on the ground.
Old Sep 14, 2011 | 09:18 PM
  #32
keithk831's Avatar
I'm about to do this tomorrow, and as I was reading through my repair manual it says to use a balljoint separator tool. Do I really need to pick one of these up?
Old Sep 14, 2011 | 11:30 PM
  #33
vinco's Avatar
No, that's just a great way to ruin your ball joint boots. Just back the nuts off a bit, but leave them on so you don't hit the threads, and give it a good whack straight down on the nut with a BFH to pop the ball joint out of the knuckle.
Old Sep 15, 2011 | 02:47 AM
  #34
keithk831's Avatar
Good enough for me! Thanks!
Old Oct 27, 2011 | 01:15 PM
  #35
whoisthis's Avatar
did you guys get red or black ES bushings? Zilvian guys are saying that black one is for self lubrication, and red one dries out over time
Old Oct 27, 2011 | 01:30 PM
  #36
04G35NYC's Avatar
I have them installed, they are a little harsher/stiffer on the roads then the OEM's but def a good upgrade.
Old Nov 12, 2011 | 08:54 PM
  #37
Cooldude04's Avatar
I installed them on my coupe as well but seems like there a little problem. It makes a clicking noise when I'm making a turn, especially when i park and try to turn my steering wheel. First i thought my tie rod but after i replaced both of my inner and outer tie rods, the clicking noise is still there.
Does any one have the same problem? I did lube the metal tube with anti-size before install them..
Old Nov 13, 2011 | 09:41 AM
  #38
68_GT's Avatar
is there a DIY to instal compression rod bushings ?
I just got my ES bushings in (mine are black). My passenger side is completely blown. Im getting all kinds of road noise and having alignment issues. Guess the AWD torque to the pass side front wheel took it out.
Old Nov 13, 2011 | 01:35 PM
  #39
Cooldude04's Avatar
there is one DIY from the Z forum. This is the link
http://my350z.com/forum/brakes-and-s...g-install.html
It's for the SPL but the method is the same for ES..
Old Nov 18, 2011 | 12:29 PM
  #40
P10 WRC's Avatar
has anyone had any issues with squeaking?
Old Nov 18, 2011 | 01:23 PM
  #41
keithk831's Avatar
Yeah, ever since it started getting colder outside I have been getting some noise...mainly when I'm just leaving my house. Suggestions anyone?
Old Nov 18, 2011 | 02:58 PM
  #42
MikeDG's Avatar
I have also noticed some squeaks lately since the temps have been falling. Like keithk831, I usually only hear it when backing out of the driveway. I haven't gotten under there to take a closer look yet, but am hoping that adding some lube will quiet them down.
Old Nov 18, 2011 | 04:50 PM
  #43
Cooldude04's Avatar
Can you describe the noise? is it a squeaking when you're turning the steering wheel? Mine is squeaking and clicking as well.. I'm about to add some lube tomorrow see if it helps..
Old Nov 19, 2011 | 12:04 AM
  #44
MikeDG's Avatar
^ The noise is more of a creaking type of sound. I get it when I turn the wheels at very slow speeds also. The weird thing is that I only notice it when the car is cold and I'm backing out of my driveway or a parking space.
Old Nov 19, 2011 | 12:53 AM
  #45
keithk831's Avatar
Same here. It's more of a creaking...like when my old bushings were wearing out.
