Knocking sound from the rear
Old Jun 28, 2011 | 12:41 AM
hologram's Avatar
Trying to find out what is that is causing my rear to make a metallic knocking sound when driving into my driveway, OR when turning slowly but aggressively into a corner.
Arizona houses have a crummy bump style driveway and half the time I hear a knock after my front wheels are already over the bump(and 45 degrees in) and the rear starting to come up in the driveway.
So Im trying to find out what the actual problem is, so that I can correct it.
Old Jun 28, 2011 | 12:49 AM
4DGS's Avatar
Any modifications?
Old Jun 28, 2011 | 01:01 AM
hologram's Avatar
Originally Posted by 4DGS
Any modifications?
Bone stock.
Old Jun 28, 2011 | 01:24 AM
Eric@TCGMiami's Avatar
Axle TSB
Old Jun 28, 2011 | 01:29 AM
hologram's Avatar
Originally Posted by Eric@TCGMiami
Axle TSB
I tried looking that up, I'm a little bit confused.
Old Jun 28, 2011 | 01:34 AM
Simple test..
Turn on the car put you windows down and open the driver side door. Place foot on brake and keep it there. Then place the car in reverse did you hear a click? Then put it in drive was it the same click?? Disregard the transmission engagement ... you have to listen to the rear axles.
If it clicks that's the axle tab.
If no click then its potentially worn bushings especially if you live in the states where the county spreads salt on the tarmac.
Old Jun 28, 2011 | 01:37 AM
4DGS's Avatar
I wouldn't say it the axle if he's hearing when going up an incline. That sounds a lot more like a bushing that has either popped out or worn out.
If you it is the Axle, the dealership should lube it up for you free of charge. If it isn't, then take it to you mechanic and have him poke around at the rear end bushings.
Old Jun 28, 2011 | 01:42 AM
hologram's Avatar
They replaced my front bushings a while ago, they never found anything "wrong" with the rears...fkin idiots. Also Im out of the warranty on it(unless its under the powertrain, 07 coupe w/ 38k miles or so)
Also arizona, has no salt on the roads, so thats not gonna cause a problem.
Old Jun 28, 2011 | 02:06 AM
4DGS's Avatar
Yea the front's will probably go again in the time you own the car.
Most dealerships are good about the axle click and will do it just because it's simple. But there is a DIY on here to lube it up, I just can't recall where it is. Do a search and it'll pop up.
Old Jun 28, 2011 | 02:09 AM
PAIXAO's Avatar
Rear end link or rear camber arm. My bet is one of those has a worn bushing.
Old Jun 28, 2011 | 02:13 AM
hologram's Avatar
Real question is now, besides talking to the dealership about the rear axle needing to be lube'd up is where do I find the bushings, which one's i need and which one's are the best one's to go with, OEM Vs aftermarket.
TWASkyliner
Feb 8, 2020 08:00 PM
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
atk08
Jul 30, 2015 03:12 PM
rping
Jul 26, 2015 09:53 PM
