Brembo brake size
Old Sep 21, 2011 | 05:11 PM
R6n350GT's Avatar
Brembo brake size
I am trying to compare my current brembos off my 03 6MT with others out there. I have the stage 2 stoptech slotted rotor kit (these size any different to stock?)
355mm 4 pot kit a friend is selling for $750 (this cheap for fronts?)
I cant find anywhere what the size of ours are...
Can anyone help?
I found a heap of info on BBK
http://www.350z-tech.com/wiki/index.php/Big_Brake_Kits
But no stock specs
Thanks for all your help
Old Sep 21, 2011 | 05:13 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
OEM Brembos are 332mm (13" rotors)
Old Sep 21, 2011 | 05:15 PM
R6n350GT's Avatar
Dam, after 1 or more hours of searching u answer in 10 seconds!!!
Is that the same for front and rear?
355mm is that a BBK or standard?
Thanks
Old Sep 21, 2011 | 06:01 PM
355mm is a 14" rotor. The Akebono (G37S) brakes are 14" rotors.
The rear on own Brembos is a little under 13"
Old Sep 21, 2011 | 06:05 PM
R6n350GT's Avatar
So i cant use these 355mm on my stock rotors?
Old Sep 21, 2011 | 06:18 PM
Quimby's Avatar
afaik 355mm refers to the rotors, not the calipers
Old Sep 21, 2011 | 09:02 PM
R6n350GT's Avatar
I was also told we have 256mm size but above says 332mm..
That they are 13" which is 330mm (both front and rear??)
I have the stoptech slotted powerslot rotors with stock brembos
I would love to know the mm for front and rear as its not on their website
I would also like to know what spec the 4 pot front and 2 pot rear brembos are,
what size rotor they are compatible with and what size calipers we can fit on the stoptech rotors i have..
Its all very confusing and wish there was a nice post that had all the info.
Anyone know enough to help with the above?
Old Sep 21, 2011 | 10:13 PM
There won't be any calipers you can use with your current rotors, nor would you want to since you already have 4 piston calipers. Moving up to a 6 piston caliper requires a 14" rotor in most if not all cases.
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Popes
Jul 29, 2015 05:07 PM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
