Does this look like a torn compression rod bushing?
Old Dec 22, 2012 | 06:27 PM
akogan79's Avatar
Been having a very light vibration while driving, especially over 70 mph. Decided to look at the bushings on the compression rods since so many people have problems with them and here is what i saw. To me it looks torn but I wanted to get your guys opinion.
Old Dec 22, 2012 | 06:37 PM
lsmooth81's Avatar
Do u see any fluid oozing out? Can't tell by pic.
Old Dec 22, 2012 | 06:40 PM
akogan79's Avatar
I'm not sure if bushings are supposed to have fluid in them. I thought they were just made of rubber.
Old Dec 22, 2012 | 07:48 PM
jdm-v35's Avatar
doesnt look torn. when i changed mine there wasnt any fluid in it, just solid rubber. usually if its torn it will be slid all the way to the top or bottom also and wont be centric like in the pic.
Old Dec 22, 2012 | 08:21 PM
mrgrey's Avatar
Some of the bushings do have liquidy substance inside, For example, the rear subfram diffrential.
As far as yours, I am concerned about that black stuff, it looks fresh and darker color then the rest of the bushing. Therefore, I KIND OF think it looks torn.
Old Dec 22, 2012 | 09:04 PM
akogan79's Avatar
I agree, the darker color looks like fresh rubber which makes me believe its a tear.
Old Dec 22, 2012 | 09:06 PM
akogan79's Avatar
I don't think it looks centered. It looks more to the right rather than centered.
Old Dec 23, 2012 | 05:13 AM
lsmooth81's Avatar
When my bushings went bad they had a black thick liquid oozing out. I had the same liquid on my compressions rod bushings and my rear differential bushings. I asked Infiniti and they stated that the liquid is a sign that it crack and require replacement. It could be possible that when you changed your bushings were bad for a while and almost all fluid had drained out.
Old Dec 23, 2012 | 05:28 AM
lsmooth81's Avatar
Here is some more info on it, there is a TSB on it. If you have warranty it should be cover
http://trueler.com/wp/wp-content/upl...ITB08-013a.pdf
FYI, infinitihelp.com has pdf file of all TSB for our car
Old Dec 23, 2012 | 11:39 AM
AuAltima3.5's Avatar
Let's try to clear up things here.
Compression rod bushings are NOT liquid filled.
Yes. CR bushings are rubber only.
To answer the OP questions, this bushing in the picture posted is torn pretty badly.
Yes, rear subrame, diff are fluid filled.
Yes, this is why we can confirm it's torn.
Felt this was needed, there was alot of confusion in this thread.
IF the ball joints on the compression are still good, replace these with the energy suspension or whitleline compression rob bushings.
Old Dec 23, 2012 | 01:12 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Just to reiterate, CR bushings are NOT liquid filled. The only bushing on our cars that has a liquid substance is the rear differential bushing.
Old Dec 23, 2012 | 01:48 PM
akogan79's Avatar
Thanks guys, I figured it was torn. I have extended warranty so it should be covered under it. Will give the dealer a call tomorrow and see what happens.
Old Dec 24, 2012 | 10:11 PM
lotteman's Avatar
Hopefully they'll replace it under warranty because nissan/infiniti dont replace just the bushing alone, they replace the whole arm. As for aftermarket replacements go, i would stay away from energy bushings. Their compression bushing is just bad with an obvious lack of r&d. The energy bushings just fit but dont let the arm articulate the way Nissan intended them to. This eventually leads to a cracked or heavily worn energy bushing and now youre back at step 1.
I would get the Whiteline bushing. Unlike energy, whiteline actually puts some good thought into their design and designed their bushing to articulate correctly. If youre more into racey car parts you can try the SPL bearing which i personally have on my g. Instead of a soft-ish material that stretches, the SPL part is a metallic spherical bearing that articulates freely without binding whatsoever unlike the whiteline or OEM bushing. Usually spherical bearing replacements will roughen up the ride of your car but i've had mine for 2 months with a daily commute of beaten up streets and i havent noticed too much of a difference in comfort, just handling. The car is much more responsive when steering now!
hope this helps
Old Dec 31, 2012 | 05:51 PM
akogan79's Avatar
Just picked up my car from the dealer. Got the compression rods replaced on both sides and also replaced one taillight because one of the LED'S wasn't working. The bill was $1226. Unbelievable. Thank god for that extended warranty, it only cost me $100. At first when I dropped of my car off at the dealer, it sat there all day only to have the dealer call me and say nothing was wrong with my compression rod bushings. Idiots only looked at the bottom side and didn't bother looking at the top. I had to come down there to show it to them. Hopefully this will get rid of the vibration I feel at highway speed.
Old Jan 1, 2013 | 07:28 PM
akogan79's Avatar
Dude!!!!! That is so high, how do they justify it?
I agree. That is crazy expensive. Their labor rate is $130 an hour.
