Problem with wheel bearing ...
Old Jan 4, 2013 | 12:28 PM
Therzdae's Avatar
Question Problem with wheel bearing ...
HOLA!
So I had a bad passenger side wheel bearing and hub, so I followed the DIY on here and did it my self... except the pressing on I had to get Kaufman tire to do. Any who followed it just as the DIY said now in Drive, or Reverse .. any time it moves i hear a LOUD metal on metal rubbing sound... I took the wheel back off I don't see anything abnormal, sooo What should I look for it or what could it be?? Please help I miss driving my G35x! Driving the Bike in 35 degree weather aint all that great....
Thank you,
Brice Tomlinson
Old Jan 4, 2013 | 12:41 PM
Heero's Avatar
Check to make sure your dust sheilds aren't rubbing on the rotor.
Old Jan 4, 2013 | 01:00 PM
Therzdae's Avatar
Thank you sir... er mam.
Old Jan 4, 2013 | 02:13 PM
Heero's Avatar
Did it fix the problem?
Old Jan 6, 2013 | 10:13 PM
Therzdae's Avatar
It did not... didnt seem like it was touching but I bent it back all the way any who... sooo any other ideas?
Old Jan 6, 2013 | 10:39 PM
05DGx's Avatar
Just a shot in the dark; the sedan and coupe have different wheel bearing numbers, are you use you have the right part number for your diy?
Old Jan 7, 2013 | 10:02 AM
Therzdae's Avatar
I went to the infiniti dealership and just asked them for the 06 g35x wheel bearing and hub... though I believe the coupes are all one as the the sedans come as separate pieces...
Old Jan 8, 2013 | 04:29 PM
Therzdae's Avatar
no new ideas eh?
Old Jan 8, 2013 | 06:41 PM
jugger23's Avatar
put the car on the lift and then spin the front wheel.
hopefully, you'll hear where its coming from.
Old Jan 10, 2013 | 11:06 AM
Therzdae's Avatar
es unfortunately I dont have access to a lift^
But I brought it to tire shop they said its the dust shield that is pressed on to the bearing making the noise... the only way to fix is replace with a new one? ALSO my NEW wheel hub from Infiniti of Marietta GA is BENT. and Infiniti wont warranty it since I did it my self... WHAT THE FAWK!
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
wuppiedog
Aug 7, 2015 11:16 AM
rping
Jul 26, 2015 09:53 PM
