Need some help w/ an SPC rear camber kit install
Old Nov 22, 2013 | 01:03 PM
verbatum14's Avatar
I'm in the middle of installing my SPC rear camber kit and I'm hoping to get some advice. It seems as though the stock camber adjustment bolt is glued to the bushing in the camber arm. I'm able to remove the bolt attaching the arm to the hub assembly but, try as I might, the other bolt just isn't coming out. I'm able to freely move the arm and there is no more tension on it but the bolt will not slide out. The SPC guys make it look easy as hell to get it out and yet I'm beating on this thing with a rubber mallet and it's not budging. Am I missing some thing? Anyone got any tricks for this? Just for a visual of which bolt I'm refering to:
Thanks in advance.
Old Nov 22, 2013 | 01:20 PM
Golden_Shower's Avatar
That bolt should just come right out, did you take out the other bolt to loosen the tension. The bolt you have the arrow pointed two has two round washers that should be able to move in a circle to change toe.
Old Nov 22, 2013 | 06:38 PM
verbatum14's Avatar
The other bolt was completely removed. I was able to camber arm freely. The washer was removed from the adjustment bolt but this thing will not come out. It feels like the bolt is somehow fused to the bushing. I've tried dousing it in WD-40 but it made no difference. The only thing I haven't tried yet was to put the nut at the end of the bolt and hitting it with a real hammer. Very frustrating...
Old Nov 22, 2013 | 06:43 PM
Try a real hammer just be careful of the threads
Old Nov 22, 2013 | 07:03 PM
4DGS's Avatar
It's seized...
You need heat and hammer, smash it and go buy new eccentric bolts from the dealer, they're about 20$ each.
Old Nov 22, 2013 | 07:22 PM
verbatum14's Avatar
Thanks for the advice. I'll try the heat and hammer out tomorrow.
Old Nov 23, 2013 | 03:16 PM
verbatum14's Avatar
Thank 4DGS... you were right on the money. No heat but a lot of PB Blaster and I was able to twist them independently from the arm.
Old Nov 24, 2013 | 08:23 PM
JKL1031's Avatar
Mmmhhhh those r yielded...need some new ones.
Old Nov 25, 2013 | 07:45 AM
verbatum14's Avatar
Yeah I ended up picking up a new set from the dealer for $11 a piece. Not as bad as I was fearing they would be... Apparently these things seizing are a pretty common occurrence. I just wasn't expecting it to happen.
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
