Tire rubbing!
Old Nov 23, 2015 | 12:34 PM
ka8man's Avatar
Tire rubbing!
So I have an 03 Sedan dropped on BC coilovers and just started to get rubbing from the front passenger fender. The car is lowered about 2" or so, I have 20" rims and 245/35 tires. I have been riding at this height for about 6 months and suddenly I now have rubbing from the front passenger fender when turning left. I have adjusted the camber to give more negative camber but it has t helped the rubbing at all. What could make this happen after this long with no change in ride height? Could the damper be blown out causing it to sag?
Old Nov 23, 2015 | 07:40 PM
saywat?'s Avatar
wat i do is drive up a curb from a drive on the side of it so it compresses the spring and u can see where its rubbing
Old Nov 23, 2015 | 07:41 PM
VenomGT9's Avatar
Maybe add a spacer up front, 5-8mm depending where it's rubbing
Old Nov 23, 2015 | 07:42 PM
saywat?'s Avatar
if his tires are already rubbing why would u suggest adding a spacer?
Old Nov 23, 2015 | 08:55 PM
VenomGT9's Avatar
....."depending where it's rubbing"
Old Nov 23, 2015 | 08:56 PM
saywat?'s Avatar
^says fender
Old Nov 24, 2015 | 12:17 AM
ka8man's Avatar
I already know exactly where it's rubbing, paint has worn away, what is strange is I didnt change any settings, after the suspension settled it was fine for about 4-5 months and all the sudden it started rubbing. After that I added in some more negative camber as it is rubbing at the outer lip of the fender at the top apex. I just don't know why it took this long to start rubbing, and it isnt a slight rub, it is very loud. The only thing I can think is that the damper is blown causing the suspension to sagg on that side under added load. Any other thought as to why it would start after 5 months? Forgot to mention, it's not a bushing issue, lower control arms have been replaced with energy suspension bushings and the upper A arms also have new bushings.
Old Nov 24, 2015 | 12:53 AM
saywat?'s Avatar
Take a pic
brianuc4
19
Apr 10, 2020 02:12 PM
magnetism80
Feb 1, 2019 10:00 AM
vstring
Sep 21, 2015 11:14 AM
Eomfd
Aug 29, 2015 12:42 AM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
