Absolute Best Way to Remove a Wheel Bearing Assembly
Old Sep 15, 2018 | 12:55 AM
SofaKingAzn's Avatar
Hey guys, I know this should go into the DIY section but I didn't have access to post. Hope I can post it here and have the Admin move to the DIY section.
Anyways, after following the DIY for wheel bearing removal on G35Driver, I found myself at the last step hammering furiously at my wheel bearing assembly trying to pop it off. After 4 frustrating hours, I gave up. I did some research and talked with some people and stumbled on this amazing painless way to remove a wheel bearing. It literally costed be 2.47 CAD to buy the parts and it popped out my wheel bearing within 1 minute.
Go to Home depot and buy yourself 2 hanger nuts and 2 bolts like shown below: The hanger nut and bolt when completely screwed in will need to be smaller than the gap between your wheel bearing and the car. For V36 that distance is 3.5 cm.
Hanger Nut and Bolt. Buy a pair (2 hanger nuts and 2 bolts)
Place 1 pair of hanger nut and bolt above and 1 pair of hanger nut and bolt below the wheel bearing.
Place the hanger nut and bolt between the wheel bearing. 1 above and 1 below the wheel bearing so you can press out the bearing evenly.
Only thing to watch out for is to make sure the other side away from the bearing you have something solid to jack against! I have a V36 and that place happens to be between the 2 bolts holding the wheel bearing in (and 2 bolts below for the other set of hanger nut and bolt below the wheel bearing). Now that they are placed, use a pair of wrenches and turn the bolt counter clock wise (Loosen the bolt away from the hanger nut), this will put pressure on the wheel bearing and force it out. You want to press above and below evenly.
I didn't even need to turn it that hard. After being snug against the wheel bearing, I made 1 full turn above and below and immediately a thin crack between the wheel bearing assembly and the rest of my car formed. After 3 full turns my wheel bearing popped right off (Less than 1 minute). My dust shield was in perfect condition and the wheel bearing came out nice and easy and controlled. I honestly hope no one else ever uses a hammer to try to remove a wheel bearing assembly. This has been so easy and painless I am very surprised that it is not communicated more. I hope this helps and saves you guys the time and frustration I had to go through
Old Sep 16, 2018 | 08:53 PM
LoSt180's Avatar
Well damn. This is amazing.
Old Sep 17, 2018 | 11:12 PM
onevq35de's Avatar
That's solid ingenuity right there. I can't believe I didn't think of this. I almost always figure out a way to weasel an easy route but when I did my fronts, I found a sliding hammer was a joke so I just beat the ever living **** out of them with a rough construction hammer. No mallet. It didn't take too long, maybe 1/2 an hour each. I pounded side to side and top to bottom and when they came out, I pounded them a little more.
Old Sep 18, 2018 | 04:28 AM
Scorpi0's Avatar
Dude thats kinda misleading.
At first, I thought u were saying that u used that method to pull the hub off of the bearing...I was like holy śhit...it cant be that easy!!
Old Sep 18, 2018 | 06:16 AM
onevq35de's Avatar
What's misleading? It's in the title;
Absolute Best Way to Remove a ***Wheel Bearing Assembly***
Old Sep 18, 2018 | 06:42 AM
Blue Dream's Avatar
I drove ttrank's car solo
Old Sep 18, 2018 | 11:04 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yep, that's what I thought was going on too >.<
Old Sep 18, 2018 | 05:32 PM
Blue Dream's Avatar
Sorry, I just had to........
Old Sep 18, 2018 | 06:15 PM
cleric670's Avatar
BANNED!!!
Yep it's true!
studio54
Jan 22, 2014 12:06 PM
Vinzo
Archived Sales
Jan 15, 2010 02:19 PM
Smokey6
Nov 5, 2008 07:32 PM
