2008 G35X Rear Caliper Wrong Size?
Old Nov 2, 2019 | 09:51 PM
rtb1010's Avatar
Just had my driver side rear caliper freeze. Ordered rotors and pads on Amazon, same ones I previously swapped out (in 2017). Ended up getting calipers from local Nissan dealer for reasons (I now wish I hadn't but here I am overpaid), "aftermarket" calipers, which are these:
https://www.napaonline.com/en/p/SEBS...dInput=caliper - driver
https://www.napaonline.com/en/p/SEBS...dInput=caliper - passenger
Installed driver side fine, bled brake line, all good.
Got passenger bracket on, pads in, ready to close it...caliper will not go over pads. Upon further inspection, passenger caliper is almost 1/2 inch tighter than driver side and the OEM I'm replacing?? Did I (dealer) just get the wrong part or am I missing something? The originals were both the same size (and same size as the driver's new one).
Thanks for the input!
Original, 2" opening
New, a little over 1.5" space??
Comparing the two
Old Nov 3, 2019 | 12:42 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Right rear caliper on an X model should be Nissan part number 44001-EG50C
I'm guessing they accidentally gave you part number 44001-JK00A
sparklecitycarz
Jun 13, 2012 06:02 PM
Mustang5L5
Jun 19, 2011 03:58 PM
jd46
Sep 28, 2009 07:05 AM
cooldog45
Jun 6, 2007 11:09 AM
