Brake related lights on dash gauge cluster
Old Dec 16, 2005 | 12:19 AM
duhprez's Avatar
My ABS Light, the Slip light and the VDC light are all on and won't switch off when the car is running. I've tried turning off the car and turning it on several times and it doesn't help. I've tried switching the VDC off and on several times and it doesn't do anything either. The red brake light (red exclamation mark) indicator is not on just to confirm.
This happened after I stepped on the gas with the VDC switched off to get out of a snowed in parking lot. I needed some wheel spin to get the car going.
I recently had the brake pads changed on all four wheels.
Any feedback would be welcomed.
Thanks
Old Dec 16, 2005 | 01:24 PM
superchargedg's Avatar
what year is the car and is it coupe or sedan,i have an 03 coupe which i forgot to take back for brake switch recall,all my same lights were on they replaced a recalled brake interlock switch it solved all problems.hope this helps.
Old Dec 16, 2005 | 01:38 PM
duhprez's Avatar
Model year
I have an 03 Coupe.
thanks for the suggestion.
Old Dec 17, 2005 | 08:42 PM
josephsuiskind7's Avatar
Thanks
same thing just happenned to me the other night, any solution without having to go to the dealership??
Old Dec 17, 2005 | 10:16 PM
GLuXuRy's Avatar
My friends girlfriend brake pads were so low that all the those lights you guys are referring to came on for her too... maybe you need new pads??? Just a hunch
Old Dec 17, 2005 | 10:19 PM
would never drive around with pads that low, guess ill just bring it to the dealership... gotta put winter tires on anyway...
Old Dec 17, 2005 | 10:36 PM
GLuXuRy's Avatar
Best of luck to get the G right !!!
Old Dec 22, 2005 | 07:56 AM
Beachbum's Avatar
I had the identical problem this morning. My brakes probably need replaced so I'm assuming that's my issue.
Old Dec 22, 2005 | 11:37 AM
so.... dealership says theres nothing wrong with my brakes, the abs , vdc, and slip light go on any time you take of traction in order to burn through some snow ...... from my understanding infiniti replaces the breaks any time they wear down before 35k miles?, the first couple months i had my 04 sedan they would replace my pads basically without me even having to ask ... now i have horrible squeaking from time to time and ive been told my brakes are fine....
any ideas on how i can get the dealership to replace my brakes before 35k?, (im at 29k now)
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
wonderizm
Sep 24, 2015 03:09 AM
.cakestar
Aug 4, 2015 09:05 PM
ClwMike
Jul 23, 2015 12:55 PM
