GTSPEC Bars fit on Sedan
Old May 19, 2006 | 10:14 AM
  #256
bert039's Avatar
Hey leave the man alone, if he wants to sell them then let him sell them
Old May 19, 2006 | 11:15 AM
  #257
vodkarocket's Avatar
Modded Member
I wish I saw your post earlier, because I sold them last night to somebody in Washington.
Old May 19, 2006 | 03:07 PM
  #258
cato's Avatar
SouthernComfort Moderator
I was just informed by Ken at GTSPEC that the 4 point chassis brace arrived today and it would be shipped out to me today! Woo Hoo! I'm gonna get stiff!
Old May 19, 2006 | 05:05 PM
  #259
codeflux's Avatar
Boris, you did the right thing. Rob at ZCG told me that they installed the bar in the front only on one G, and it made no difference. i guess these things work in pairs only.
Old May 23, 2006 | 08:29 PM
  #260
amg35's Avatar
Florida G35 Club
Cato, did you get stiff? Any update on the 4-point brace? Thanks.
Old May 23, 2006 | 08:53 PM
  #261
codeflux's Avatar
ROFL! insert the "i'm getting stiff right here, buddy" comment here.
Old May 24, 2006 | 10:14 AM
  #262
cato's Avatar
It's in the mail right now. I need to find someone in Houston who can drill holes in my frame to attach the 4 point brace? Any suggestions?
Old May 24, 2006 | 10:51 AM
  #263
SixFive's Avatar
If Houston is like Philly maybe you can just get someone to shoot the holes in for you.
Old May 24, 2006 | 02:05 PM
  #264
cato's Avatar
We prefer lethal injection around here!
Old May 28, 2006 | 05:55 PM
  #265
cato's Avatar
Ken at GTSPEC contacted me last Monday and said he was shipping the 4 point brace. I have yet to see it arrive. Today I changed my oil in the garage. I decided to check out my underbody and and compare it to the 350Z in the install pics. I do in fact believe the G35 sedan has a configuration very similar to the 350Z. It appears that the rear of the brace is atttached at a point behind the two easily seen holes in the frame. Those two holes are present on my sedan as are the three close to the Y-pipe. There must be another hole on the 350Z that doesn't appear on the photo. Anyway, I'm pretty encouraged. I might just need two holes drilled.
Attached Thumbnails GTSPEC Bars fit on Sedan-117_1755_resized.jpg   GTSPEC Bars fit on Sedan-117_1757_resized.jpg   GTSPEC Bars fit on Sedan-117_1764_resized.jpg   GTSPEC Bars fit on Sedan-121_2152_resized.jpg   GTSPEC Bars fit on Sedan-121_2153_resized.jpg
Old May 28, 2006 | 09:21 PM
  #266
badtz's Avatar
Has anyone put on the front tie bar themselves? How hard is it? I looked at it and it seems you ahve to pull the whole bolt out of the lower front arm. It mounts on the bolt side instead of the nut side. Is the bolt hard to remove or put back in?
Old May 29, 2006 | 12:56 PM
  #267
Zat_Zuma's Avatar
Originally Posted by badtz
Has anyone put on the front tie bar themselves? How hard is it? I looked at it and it seems you have to pull the whole bolt out of the lower front arm. It mounts on the bolt side instead of the nut side. Is the bolt hard to remove or put back in?
Yes and YES ....... it wasn't fun
You'll need at least a 1/2 breaker bar to loosen the nut (3/4" is better) and their isn't much room to get a socket on the nut, as the steering components are in the way.
Once it's loose and you've supported the transverse link arm, so it doesn't move, the bolt slides in and out easily. You'll have to use a locktite material on the end of the nut when you put it back( manual doesn't show it but there was a coating of something on the threads) and torque it to 89-103 ft-lbs. The secret to a easy install is to have enough the car jacked up enough to have clearance for the wrenches and support the arm so it doesn't move. Other than that ..... it was easy
Old May 31, 2006 | 07:20 AM
  #268
cato's Avatar
4 point chassis brace arrived at my doorstep yesterday! Now for the install..........
Old Jan 17, 2007 | 02:50 PM
  #269
cato's Avatar
End of this story is that the 4-point chassis brace DOES NOT fit the sedan, but DOES fit the coupe and 350Z. I thought I would sticky this thread as it is pretty informative.
Old Jun 5, 2007 | 11:48 AM
  #270
da mayor's Avatar
that will change once GT Spec gets their new lift and my sedan goes into the shop
