Dspec+HTech (350z) with 19 wheels. Camber issue?
Old Feb 24, 2006 | 07:31 PM
FI'ed G's Avatar
guys, i just purchased my 350Z DSPEC and H-Tech, will i need some camber kit with this drop on a 19 wheels? Is it going to be way out of spec or will it be not as bad? please advice thanks
Old Feb 24, 2006 | 07:50 PM
SCoupe's Avatar
It won't be too awfully bad but it will be OUT.
Yeah, you'll prolly need a kit.
Old Feb 24, 2006 | 09:55 PM
Klubbheads's Avatar
If u have a sedan then they can align it to have -1.8 to -1.9 rear camber.
I think its perfect for this car.
Old Feb 24, 2006 | 10:01 PM
FI'ed G's Avatar
I do have a Coupe. just wondering if i can get away without getting one.
Old Feb 24, 2006 | 11:32 PM
Klubbheads's Avatar
Yes you can, your'e just going to have uneven tirewear (inside of the tires are gonna wear out sooner than the outside part of the tire).
You can swap the tires later on to eliminate (left tire on right and right tire on left) that problem.
BTW handling of the car is going to improve with negative cambers.
Old Feb 25, 2006 | 12:13 AM
FI'ed G's Avatar
And this problem will only be at the rear right? or both front and rear?
Old Feb 25, 2006 | 12:27 AM
Klubbheads's Avatar
I dont think ur gonna notice it in the front.
Old Feb 25, 2006 | 12:49 AM
FL-G35's Avatar
I have the Tein Basic set up without a camber kit on my coupe. I adjusted the ride hieght to were the rears are within spec, however the fronts have a slight negative camber. There is no camber adjustment on the front. They will wear, but as Klubbheads said, by swapping tires left to right that will help the life of your tires.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
iknowitsfast
Aug 12, 2015 02:08 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
