Canada Serving Canada.
Need Help !! Tires sizes
Old Feb 27, 2008 | 05:08 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Here's a couple of size calculators....
Plug in the OE size & find what works.
Tire size calc 1
Tire size calc 2
Old Feb 27, 2008 | 06:19 PM
noodleman's Avatar
40 profile should be good. 35 will make the tire too small for sure. 19" rims use the same widths but 35 profile tire, so if you're using 18s, 40s is the correct profile.
Old Feb 27, 2008 | 10:52 PM
lowrider's Avatar
You didn't give us the wheel widths. I assume the fronts are at least 8.5" wide and the rears 9.5". If so your size choices are golden. (40 series)
Lou
Old Mar 14, 2008 | 08:03 PM
RBull's Avatar
Rated M
You haven't provided offsets so someone can make an accurate suggestion.
Old Mar 14, 2008 | 08:15 PM
codeflux's Avatar
another excellent tire size calculator: http://www.rims-n-tires.com/rt_specs.jsp
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
mryogi
Aug 14, 2015 07:58 PM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
