Winter Tires Info - Great White North
#121
on
Originally Posted by cycleguy55
As of this writing, I'm not yet convinced those are our only two options. For one, the service manual indicates a way to calibrate the system w/o any tools (by using specified and distinct pressure in each tire).
I had read through the manual as well when I started this whole winter tire ordeal, I miss the old city dwelling days when I never had winter tires I tell you!
It is my understanding that even with this method of allowing the car to sense the sensors it still needs to be put into a "program mode" through the ob2 port first? Ie you still have to trigger it to look for the new sensors at their respective pressures and then turn off... I hope Im wrong though... we should get 15 guys and buy one of those bad boys though and just be done with it!
S.Dunn
#122
on
Originally Posted by Ian_H
Good write up S. Dunn
Just got my car back today. 17 inch CR superlite wheels wrapped in 225/50R17 Nokian Hakka R's. I guess we will see how they are with snow. One thing I noticed was that the TPMS light didnt come on which was odd.
Some times it takes quite a while to come on. Also Im not sure how far the sensors work and my tires are stored in the garage so... maybe that works in my favor. My light also has yet to come on.
I have no doubt you will like the tires... just not quite as much on smooth dry pavement. Had some guy in a Pontiac g6 coupe today try to show me how fast his car was... I haven't scene a slip light blink quite that much ever... it was like waiting for turbo lag to hit... finally it stopped slipping and grabbed and the thing took off like a bat out of hell... but it certainly wasn't like the much wider performance tires of the summer... Why the hell wont it snow again?
S.Dunn
#123
on
SICK Deal
Originally Posted by gcoupe_toronto
Just picked up a set up Nokian Hakkapeliitta R for my coupe...if anyone is interested in GTA PM with your tire size and I will get you a price, I paid $900 (NOT installed)
I got couple of quotes from tire dealers with a avg price of $1100 +
Granted you didn't tell me sizes but if your going to a 215/55 17 should be around 230 per tire. I have no clue what a 235 45 18 would price at... More no doubt
If its tax in its not bad I guess... I would think they would throw in mounting if they are selling you the tires. What warranty is offered by the shop. What does the shop want to slay you for install?
I think I paid $1225 for the tires mounted balanced and new valve stems. This was including tax in british columbia, obviously not including rims. The tires were 215/55 Nokian Hakkapeliitta 5's which sell for a little bit more than the R (however most people don't need the 5 and would be better off with the R).
Thanks for the info... no doubt it is a good deal... just need to clarify. Im sure people in the GTA appreciate you trying to hook them up!
S.Dunn
#124
#126
Originally Posted by nibble
Well I just picked up a set of Blizzak LM25s, and I'm praying that they'll get me through a Toronto winter unscathed. I almost wet myself on my Toyo Proxes 4s when I bought my G35 Coupe and we had one final snow fall for the season. I would have liked to get a hardcore winter tire, rather than a performance winter tire, but I really wanted to keep my 18 inch rims on. Comments appreciated.
I wasn't sure how the Proxes 4s were in the snow and ice as there haven't been many reviews. But for a High Performance A/S, I highly recommend the Pilot Sports!
I think you'll be impressed with the dry traction and handling of your new LM-25s. Even the snow and ice traction is better than many of the 'other brand' winter tires out there.
#128
Tire Pressure Reset Tool for Nissan??
S.Dunn
S.Dunn
http://www.otctools.com/products/detail.php?id=2444
http://www.otctpms.com/products/nissanreset.php
http://www.usatoolwarehouse.com/usat.../OTC-3831.html
Does anyone out there have any experience with the "Tire Pressure Reset Tool for Nissan", how it works, etc.?
#129
20" steelies?
Originally Posted by vat_U_tink
I got a BBK kit on my car.
According to the dealer i can't fit ANYTHING less then 20's
Do you guys know anythere that sells 20 inch steelies? OR winter quality rims.
The current size im running is 285/30/20 rear 245/35/20 front.
Any input would help me ALOT.
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
BTW, which BBK do you have?
#130
#131
Thanks for the comments. I feel better about my purchase now, and I can't wait to see how they are for myself. As for the Proxes 4s, you definitely made a good decision not getting them if you're at all concerned about snow traction. Unfortunately I can't really compare them to anything else as far as regular all seasons go since they're the only tires I've ever had on my G. I'll get a better idea of how good they were once the winter season is over and I get a new set off tires.
![Stick Out Tongue](https://g35driver.com/forums/images/smilies/tongue.gif)
Michelin is just releasing the replacement Pilot Sport A/S Plus which according to Tirerack, is even better and has a higher treadwear rating. Unfortunately, I just got mine a few weeks ago and they aren't available here yet. Not even listed on the Canadian Site. So if you're replacing your Proxes 4s, you might want to give the new A/S Plus a try.
#132
#133
^^^^ Bob. Your wheels and tires should be posted here on Marketplace: https://g35driver.com/forums/wheels-tires-fs-100/
Good luck on your sale
#135
I had a good test run on a new set of Blizzak WS-60 this morning.
I hit a variety of road conditions on the way into work this a.m.
- hard pack (icy)
- 4-6" fresh snow
- slush
I was really impressed with the traction through all conditions.
But braking on the icy hard pack was especially outstanding
These are my 1st Bizzaks & initial impression is.
![](https://www.z4-forum.com/forum/images/smilies/happyclap.gif)
....the only other thing, is just how long they hold up at this performance level.... time will tell.
- hard pack (icy)
- 4-6" fresh snow
- slush
![JAMIN](https://g35driver.com/forums/images/smilies/jammin.gif)
![](https://www.z4-forum.com/forum/images/smilies/smilie_thumbsup.gif)
![Dunno](https://g35driver.com/forums/images/smilies/dunno.gif)
