Canada Serving Canada.
Mod Shop... Calgary?
Old 03-27-2010, 01:44 PM
Eno's Avatar
Eno
Eno is offline
Cool
You coming down for the meet Red? I'll forward you a list of all the gas station locations you'll likely need between here and there.
Starting with Leduc...
eno
  #167
Old 03-27-2010, 06:48 PM
Sylvan lake V35's Avatar
eno
his car is farther from being done than mine!!
  #168
Old 03-27-2010, 11:05 PM
red35's Avatar
eno
I wish i could but the looks pretty bad right now. Missing alot of pieces. Next week it should start going back together.
  #169
Old 03-27-2010, 11:10 PM
Swivel's Avatar
Moderator
Eno's car looks really good. Pics soon.
  #170
Old 03-28-2010, 04:14 PM
G35thrilla's Avatar
eno your car is like a twin of mine hahaha.. cant believe i missed the meet dam it.. eno i sent you a pm when you have some time can you respond. ill actually ask on here as well.
So eno had his car done and got a custom map put on. since he has the same "engine mods" i do am i able to use the same map that cam made for his ride?? or will it have to be custom tuned from step 1?
thanks
  #171
Old 03-28-2010, 04:27 PM
6MTKeith's Avatar
They should be able to load the map onto your AP, but it might be a good idea to run it on the dyno or at least Data log it before you drive away. Unlikely, but your car could run completely different than his.
Speaking of which; My Access port **** the bed yesturday. Reads "Fatal error. Contact customer support." with a cute little access port guy with X's for eyes. Awww... ****ty part is i was data logging different maps and am stuck in Stage 2 91+ with 2 degrees advance. Car runs great, but under heavy accelleration i'm running avg. 12.1 A/F and as rich as 10.5! Better rich than lean i guess... I'll scan tool the ign. back 2 degress for now, but it won't help the fuel.
  #172
Old 03-29-2010, 10:12 AM
Eno's Avatar
Eno
Eno is offline
Thumbs up
Eh guys. Something that cropped up on conversation at this meet last weekend was changing the timing. I thought at first they were talking about moving their watches forward to which I smugly thought to myself "a bit late for that now, boys."
Then I realized they were talking about something to do with the car- I heard the expressions "easy" and "mad horsepower" and decided that maybe I'd inquire about how I might have such a thing done. No more accidental low grade fuel fillups though, I hope!
Also, Thrilla- sorry I didn't get straight back to you on that... I wasn't too sure of the answer but looks like someone landed that for me.
Eno
  #173
Old 03-29-2010, 11:22 AM
Swivel's Avatar
Moderator
For the curious: The guy who did the 2 degree timing advance is can350z, I think his name is Randy and he's from Red Deer, you can probably contact him on my350z.com.
Ian you probably want to check with Cam before doing that (others chime in?) since it may mess with your tune and/or it's already part of your tune.
  #174
Old 03-29-2010, 11:13 PM
6MTKeith's Avatar
Incase anybody cares, Cobb sent me an update and repaired my access port. TOP NOTCH service from those guys!
As far as the 2* advance, "mad horsepower" deffenitely doesnt come to mind. However, while reading a/f with and without 0*, 1* and 2* advancements, the data log shows a more complete burn with the advance after roughly 5000 rpm.
  #175
Old 03-30-2010, 12:53 PM
I think a timing advance would be pointless with a custom tune since that is one of things that you change when tuning. You might even lose power if the timing has been advanced more than 2deg already with your tune . As far as I know 2deg advance is a safe bump for people that have no method of tuning, however when getting a tune the timing would be advanced to an optimum setting to make the most safe power. I would guess it would be more than 2deg.
Swivel is correct you should talk with your tuner before changing things like timing if you don't know what your doing it could cause problems one of those problems could be a lean issue and that can = holes in your pistons.
I have also heard COBB has great support and quick turnarounds.
  #176
Old 03-30-2010, 02:41 PM
spellcaster's Avatar
wow there was a meet ... oh well my car was rear eneded couple of weeks ago so i wouldnt have ended up coming down anyway !!!
when is the next meet ?
All you TT holders make me feel sooo powerless
  #177
Old 03-31-2010, 10:01 AM
Eno's Avatar
Eno
Eno is offline
Reading you all loud and clear. Won't be touching the timing! Although something else that did grab my attention was the talk of that turbo installed for 6k... from that guy making his own- apparently it tucks underneath? Where does one scan that action?
eno
  #178
Old 03-31-2010, 10:56 AM
Swivel's Avatar
Moderator
^^ 350Z T - Sasha. He's a vendor on my350z as Boosted Performance. Not sure of his prices, but most agree his work is good and a huge performance bargain. He'll undoubtedly be out to the Alberta meets this year.
  #179
Old 03-31-2010, 11:44 AM
GD-Up's Avatar
  #180
Old 03-31-2010, 12:15 PM
nice I like it, how much is the boost for one of these ?
Quick Reply: Mod Shop... Calgary?
