Canada Serving Canada.
What kind of block heater on our cars?
Old Jan 3, 2010 | 07:48 PM
G35fromTO's Avatar
Do you guys know which kind came standard from the factory? Does it warm up the oil or coolant?
TIA!
Old Jan 3, 2010 | 07:52 PM
Msedanman's Avatar
O.F. Administrator
TIA!
It's a coolant immersion block heater located in a frost plug.
Colin.
Old Jan 3, 2010 | 08:24 PM
RBull's Avatar
Rated M
now that's a detailed answer.
Old Jan 4, 2010 | 07:43 AM
G35fromTO's Avatar
Cool, thanks! That's the one I thought it would be.
On an unrelated note... why can't the heater put a little more heat out in this car!?
Old Jan 4, 2010 | 08:03 AM
GEE35FX's Avatar
That is all that is required. Your engine block is an enormous heat sink. If you wanted more heat you would need to install 2 heaters and your electricity bill would take a big jump.
Years ago on my 440 Cuda I had two block heaters installed, one on each side of the block.
Old Jan 4, 2010 | 08:08 AM
G35fromTO's Avatar
Sorry, I meant when I'm already driving, I find the heater fan not warm enough for me.
As for the block heater; used it first time last night, and the engine/coolant definetly warmed up a lot quicker, so I'm pleased with that!
Old Jan 14, 2010 | 10:29 PM
TheG35Dude's Avatar
T-stat could need replacing.
Old Jan 14, 2010 | 10:39 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
^ most likely
or the heater core could be bad.
Old Jan 16, 2010 | 02:58 PM
G35fromTO's Avatar
Thanks guys for the suggestions.
ghost_g35
Aug 7, 2015 10:31 AM
KevinnnVo
Jul 28, 2015 06:29 PM
ClwMike
Jul 23, 2015 12:55 PM
mjfenix
Jul 17, 2015 02:07 PM
